rainhunter
- Mar 5, 2022
I'm running Bluefin since yesterday and wanted to activate the nfs service.
This failed with the following error message:
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 181, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1255, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1284, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1152, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/service.py", line 158, in start
raise CallError(await service_object.failure_logs() or 'Service not running after start')
middlewared.service_exception.CallError: [EFAULT] Nov 24 19:55:36 systemd[1]: Starting NFS server and services...
Nov 24 19:55:36 exportfs[1598127]: exportfs: can't open /etc/exports for reading
Nov 24 19:55:36 systemd[1]: nfs-server.service: Control process exited, code=exited, status=1/FAILURE
Nov 24 19:55:36 systemd[1]: nfs-server.service: Failed with result 'exit-code'.
Nov 24 19:55:36 systemd[1]: Stopped NFS server and services.Version: TrueNAS-SCALE-22.12-RC.1
CPU: 12th Gen Intel(R) Core(TM) i3-12100T
RAM: 46.8GiB
RAM: 46.8GiB
