Error on Drive During Test With Badblocks
hunter
I have been testing a used 3 Tb drive I recently purchased. Currently it's on my TrueNAS box but not a member of any Zvol.
It passed the smartctl short and long tests, so I started badblocks and immediately found the following new errors in the log:
Jan 9 21:37:33 freenas ada0 at ahcich2 bus 0 scbus3 target 0 lun 0
Jan 9 21:37:33 freenas ada0: <HGST HUS724030ALA640 MF8OAA70> s/n PN2234P8J5BE9R detached
Jan 9 21:37:33 freenas (ada0:ahcich2:0:0:0): Periph destroyed
Jan 9 21:37:37 freenas (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 9 21:37:37 freenas (aprobe0:ahcich2:0:0:0): CAM status: ATA Status Error
Jan 9 21:37:37 freenas (aprobe0:ahcich2:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT )
Jan 9 21:37:37 freenas (aprobe0:ahcich2:0:0:0): RES: 51 04 00 00 00 40 00 00 00 00 01
Jan 9 21:37:37 freenas (aprobe0:ahcich2:0:0:0): Retrying command, 0 more tries remain
Jan 9 21:37:37 freenas (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted
The badblocks test seems to be continuing despite the errors. The drive no longer shows up under Storage --> Disks, yet the badblocks program seems to continue running. Can anyone tell me if the errors mean I will have a problem using this drive for data? Or if the errors are due to the drive itself having a problem as opposed to the cable or something else I might be able to fix?
This can be caused by cabling
It was bad enough to get kicked it looks like. Id be very leery of this drive.
hunter
Thank you very much @John Digital. I later found 7 reallocated sectors in the drive's SMART data so sending it back. I will also try some more testing to rule out a cabling issue, possibly in addition to the drive's problem(s).
