Error on Dataset "files" cant clear
aDeWaRD
Hi to every one! My english sucks so hard... So i try to explain the problem...
first of all My System:
Case: AeroCool Xpredator III White
M.B.: Machinist MR9A PRO MAX
CPU: X99 LGA 2011 - Xeon E5-2630L V3.
Cooler: CoolerMaster Hyper 212 RGB Black Edition
RAM: 128 GB DDR4 ECC
Storage: (2x Z2 Pool) - 2x 15HDD Seagate Exox X16 16Tb (30HDD)
-> 2x PCI Express x16 nVme M.2 Adapter With 3xJMB585 5 SATA Ports
--> 2 Card Express x16 nvme M.2 (Need Bifurcation)
--> 3x JMB585 5 Sata Port per pcie card (Total 2 x 3 = 30 SATA Port)
Network: Dual 40Gbps Fiber Card (Reduce to 1x 10Gbps to Local Network)
The sistem Work properly and fine from July. Just 1 week ago, need to update airflow and finish the case project. In the proces I disconect 5 HDD power, when i turne it on i see that the Z2Pool 0 was offline on Dashboard. I shutdown, and review I don see anything, i plug it on and off another 7-10 times at I see the problem.
When I connect again the HDD the pool goes UP with other Pool. Ok... At the 2-3 hours I see that error apear... I see and all error comes from (Geom_stat / Geom_latency from Dataset). I Scrub all pool (48h) but the error persist.
I decide to move Dataset to boot_pool. Now the error change "name" when i do zpool status -x -v
On all time the sistem work properly... But now I have OCD All works, all HDD ONLINE and OK STATUS.... but on the pool where had the dataset files have a advise becasuse have the errors...
What can I do to clear the errors? What can I do to prevent these errors from appearing?
Thank you...
aDeWaRD
Solved.
1 - Move Dataset to boot_pool drive
2 - Restart
3 - Scrub Pool where was the "error files preivusly"
4 - Pool at the end goes to all OK 0 error.
