Error in shell after restart
abe_one
Hi everybody.
Today being on vacation, I decided to give the server a clean (I have 2 cats and despite the filters a bit of dirt enters).
I dismantled all the fans and cleaned them well.
Then I reconnected the server and turned it on.
Everything works perfectly as always, but the shell gives me this error every 30 seconds:
"Dec 28 18:59:16 home collectd[3132]: write_graphite plugin: getaddrinfo (freenas_server, 2003, tcp) failed: hostname nor servname provided, or not known"
I can only understand the word plugin, and I'm sure I do not have any other plugins installed by me, outside of Plex.
Can you help me?
I use version 11.2 updated yesterday with the latest STABLE update
nojohnny101
Are you sure you plugged the Ethernet cable into the same Ethernet port on the back when reconnected everything?
DrKK
FreeNAS Generalissimo
getaddrinfo is a DNS lookup command. Did he lose his nameserver?
What happens when you drop to shell, and type something like "drill www.ibm.com"
