Error: [EFAULT] Failed to set NT password for <username>: Username not found!
Muteki
Hi all,
I'm a new user to TrueNAS Core and have set up my Storage Pool, Datasets, SMB Share and ACLs as per this video.
However when I try to connect to the share I get "The specificed network password is not correct".
Version: TrueNAS CORE Version: TrueNAS-13.1-MASTER
I've tried:
Configuring SMB service for Enable SMB1 support
Configuring SMB service for NTLMv1 Auth
Enabling SMBv1 in Windows
Enabled NTLMv2 in Windows
I also noticed the following error:
smb.synchronize_passdb0.00%
Status: FAILED
Start Time: 2023-08-17 21:45:11
Finished Time: 2023-08-17 21:45:11
Error: [EFAULT] Failed to set NT password for gaz: Username not found!
and tried the following steps listed in this thread:
rm /var/db/system/samba4/private/passdb.tdb midclt call smb.synchronize_passdb -job
but still having the same issue even running this command with or without SMB service enabled:
middlewared.service_exception.CallError: [EFAULT] Failed to set NT password forgaz: Username not found!
# rm /var/db/system/samba4/private/passdb.tdb # midclt call smb.synchronize_passdb -job Status: (none) Total Progress: [________________________________________] 0.00% [EFAULT] Failed to set NT password for gaz: Username not found! Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/passdb.py", line 187, in synchronize_passdb await self.middleware.call('smb.update_passdb_user', u) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1279,in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1236,in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/passdb.py", line 105, in update_pass
Any thoughts here, not sure what to do next!
Using a nightly build isn't exactly a smart way to get to know a new system.
All kinds of things can be broken without notice in the nightlies.
If you want to reinstall with 13.0-U5 and come back if you still have some problems, that would be the right way to go about it.
Muteki
Noted, I actually inherited this 2nd hand. I have the new image down and will start from scratch.
Muteki
@sretalla Yep, clean install, working fine - obvious step is obvious! Thanks so much :)
Running TrueNAS-13.0-U5.3 if anyone runs into a similar issue using a nightly.
