fabio.soggia
- Oct 8, 2021
Hello. I built a pool with a single disk, now trying to add a second mirror disk to the pool for test. Disks are identical, but procedure says it is too small (both crucial nvme 1tb, 1 week old). Disk 1 is empty, just pool initial settings, so no problem to destroy the pool, but what if it was in production system?
TrueNAS-12.0-U6 core
Read of a guy having same problem with U1, but solved with U5
Any suggestion? Many thanks
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/attach_disk.py", line 82, in attach
await job.wrap(extend_job)
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 496, in wrap
raise CallError(subjob.exception)
middlewared.service_exception.CallError: [EFAULT] concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 214, in extend
i['target'].attach(newvdev)
File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 2030, in libzfs.ZFSVdev.attach
libzfs.ZFSException: device is too small
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 94, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 217, in extend
raise CallError(str(e), e.code)
middlewared.service_exception.CallError: [EZFS_BADDEV] device is too small
The above exception was the direct cause of the following exception:
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 398, in __run_body
rv = await self.middleware._call_worker(self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1227, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1154, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
middlewared.service_exception.CallError: [EZFS_BADDEV] device is too smalldiskinfo -v nvd0
nvd0
512 # sectorsize
1000204886016 # mediasize in bytes (932G)
1953525168 # mediasize in sectors
0 # stripesize
0 # stripeoffset
CT1000P2SSD8 # Disk descr.
2211E619079A # Disk ident.
Yes # TRIM/UNMAP support
0 # Rotation rate in RPM
root@truenas[~]# diskinfo -v nvd1
nvd1
512 # sectorsize
0 # stripesize
0 # stripeoffset
2211E6190998 # Disk ident.
