epair0a consumes DHCP leases with changing MAC addresses
bal0an
For a while now I observe my DHCP server giving out DHCP IPv4 leases to a freenas resource (the listing is from my router, a avm fritz box 7270):
The cause for the ever changing IP addresses is a randomized MAC address of the epair0a device in freenas. The MAC address seems to be randomized at system startup which my freenas does on a daily basis (it is a backup server and does not need to run 24/7 - saves me money on my electricity bill)
Is there any way make epair0a use the same MAC address and prevent DHCP lease space pollution?
Regards, baloan
Dusan
Are you using jails (or plugins)? How is the jail network configured (VIMAGE, NAT, ...)?
Could you please post the output of ifconfig?
bal0an
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>​
ether 00:25:22:b3:18:f2​
inet 192.168.178.25 netmask 0xffffff00 broadcast 192.168.178.255​
nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>​
media: Ethernet autoselect (1000baseT <full-duplex>)​
status: active​
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>​
inet6 ::1 prefixlen 128​
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6​
inet 127.0.0.1 netmask 0xff000000​
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>​
ether 02:fe:4a:c8:9c:00​
id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15​
maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200​
root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0​
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>​
ifmaxaddr 0 port 8 priority 128 path cost 2000​
member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>​
ifmaxaddr 0 port 3 priority 128 path cost 20000​
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>​
ether 02:81:e0:00:08:0a​
inet6 fe80::81:e0ff:fe00:80a%epair0a prefixlen 64 scopeid 0x8​
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255​
media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>)​
status: active​
bal0an
The jail should be using a fixed IP address (the one configured in your screenshot). Are you sure it's the epair / FreeNAS doing those DHCP requests?
You may want to create a bug report here: https://bugs.freenas.org/projects/freenas/issues
Well, pretty sure. The MAC address marked in my router as active matches the epair0a MAC address. Doesn't match with the screenshot as I happened to switch routers just yesterday to adress connectivity problems. Apologies for the confusion.
Lukas
Coincidentally, I just started seeing this exact problem in my router I installed yesterday. Any news on that?
bal0an
I have migrated to freenas 9.2.1. The problem has disappeared.
