Hey All -
Trying to setup an automated replication task from my local server to a remote server using the same version of TrueNAS Scale. Something seems off with the encryption configuration - if I disable encryption in the task it works fine, if I enable encryption I get this cryptic error:
I have no idea what its telling me the problem is, any ideas on why encryption seems to cause problems here?
Both the local pool and the remote pool have their own passphrase encryption if that matters.
Thanks
CRITICAL
Replication "Volume1/VirtualMachines/SVR1 - Volume1/Snapshot_Backup" failed: cannot receive new filesystem stream: encryption property 'encryption' cannot be set or excluded for raw streams..
2022-09-07 08:39:13 (America/Chicago)I have no idea what its telling me the problem is, any ideas on why encryption seems to cause problems here?
Thanks
