I'm getting the same failure from the UI (https://bugs.pcbsd.org/issues/6608), but it appears there may have been some upstream issues with the GUI update 9.2 -> 9.3 that I just performed.
This is my first failure with FreeNAS, and I'm still researching my recovery options. As suggested, I did backup my Config. Now looking for the method to restore it.
Regards,
Tony
Traceback
/data/update.failed
Regards,
Tony
Traceback
Environment:
Software Version: FreeNAS-9.3-STABLE-201412090314
Request Method: GET
Request URL: http://192.168.1.90/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
88. response = middleware_method(request)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_request
181. language = Settings.objects.order_by('-id')[0].stg_language
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in __getitem__
132. return list(qs)[0]
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in __iter__
96. self._fetch_all()
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in _fetch_all
857. self._result_cache = list(self.iterator())
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in iterator
220. for row in compiler.results_iter():
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py" in results_iter
713. for rows in self.execute_sql(MULTI):
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py" in execute_sql
786. cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/backends/util.py" in execute
53. return self.cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/utils.py" in __exit__
99. six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py" in execute
452. return Database.Cursor.execute(self, query, params)
Exception Type: OperationalError at /
Exception Value: no such column: system_settings.stg_guicertificate_id/data/update.failed
raceback (most recent call last):
File "/usr/local/www/freenasUI/manage.py", line 42, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 272, in fetch_command
klass = load_command_class(app_name, subcommand)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 75, in load_command_class
module = import_module('%s.management.commands.%s' % (app_name, name))
File "/usr/local/lib/python2.7/site-packages/django/utils/importlib.py", line 40, in import_module
__import__(name)
File "/usr/local/lib/python2.7/site-packages/south/management/commands/__init__.py", line 13, in <module>
from south.management.commands.syncdb import Command as SyncCommand
File "/usr/local/lib/python2.7/site-packages/south/management/commands/syncdb.py", line 20, in <module>
from south import migration
File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", line 15, in <module>
from south.migration.migrators import (Backwards, Forwards,
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 10, in <module>
from django.core.management.commands import loaddata
File "/usr/local/lib/python2.7/site-packages/django/core/management/commands/loaddata.py", line 270, in <module>
class SingleZipReader(zipfile.ZipFile):
AttributeError: 'module' object has no attribute 'ZipFile'
