Bikerchris
- Mar 22, 2020
Apologies, found that the "remove spaces from host" fixed the problem immediately. Thank you search facility, promise I used you before finding the existing solution!
www.truenas.com
Re: TrueNAS Core: TrueNAS-12.0-U8.1
Hello All,
Happy New Year.
I've come across a little error, it's may not be a TrueNAS's problem but it appears my emails notifications are not getting through.
I use IONOS for the email account sending emails.
A (free) Google account receives them.
Here's an extract of the mail delivery error message found within the IONOS mail inbox (X's have replaced any data considered dicey to make public):
if anyone else has experienced this and resolved it, I would be very grateful to know.
Many thanks,
Chris
SOLVED - Can't send email to Gmail
Hi guys. I am having issues setting up email notifications using my gmail account. The error i get is this: [EFAULT] Failed to send email: Connection unexpectedly closed What i have set up right now: FreeNAS-11.2-U2.1 Root user config -> mymail@gmail.com From E-mail -> mymail@gmail.com...
Hello All,
Happy New Year.
SMTP error from remote server for TEXT command, host: gmail-smtp-in.l.google.com (XXX.XXX.XXX.XXX) reason: 550-5.7.1 [212.227.126.187] Messages missing a valid messageId header are
not
550 5.7.1 accepted. XXXXXXXXXXXXXXXXXXXXXXXXXXXX.233
- gsmtp
Many thanks,
Chris
