Here is the equipment:
3 Dell R610's
1 HP380p gen8 + (2) disktrays 56Tb total drive space
all use single 10 gig nic's.
Currently they are all running happily through a cisco switch, but it only has 4 10 gig ports. I need to add 2 more R610's. Each R610 is running 35-40 vm's. The HP380 (Freenas) is the only storage via iscsi. Hypervisor on the R610's is Xenserver 7.2.
What I would like to know is there a way to put 3 dual 10gig nic's in the HP380 and have it act as a switch using iptables or bsd equivalent? I have very low knowledge of BSD and am not sure if it will act the same way as Linux? BSD isn't Linux, right? The reason for this is that it saves me from buying the new switch, until later and it will save us space and power charges at the colo.
Thank you for your insights!
3 Dell R610's
