[EINVAL] sharingsmb_create.path_local: SMB shares containing the apps dataset are not permitted
andresuporte
Hello
I'm getting this message when trying to share folders within a HD pool via SMB
"[EINVAL] sharingsmb_create.path_local: SMB shares containing the apps dataset are not permitted"
The error code indicates that I cannot share app datasets via SMB
Although there are some app datasets within the pool, this is not what I want to share
I see as if the datasets have hijacked the entire HD pool and it doesn't allow me to share other folders
The datasets are in "/mnt/HDD/ix-applications" and "/mnt/HDD/APP..."
The folders I want to share are in "/mnt/HDD/rede"
Can you help me get around this error?
anodos
Sambassador
Are you selecting `/mnt/HDD` or `/mn/HDD/rede` when trying to the share? Former is not permitted when ix-applications dataset is located within HDD pool, but latter should be fine (unless it's a symlink back to a path within the former -- and a few other edge cases).
andresuporte
The paths I want to share are inside the "/mnt/HDD/rede" folder. These are all folders within this directory
The issue is that I can't share any folder that is within the pool, be it "/mnt/HDD/rede", "/mnt/HDD/rede/anyfolder", ""/mnt/HDD/anotherfolder" etc simply because there is a dataset configured in this pool
I checked the folder permissions for /rede, for example, and it says "drwxr-xr-x" (755). Even if I apply chmod 777, I can't share it. This folder was created after configuring the datasets and installing the applications
Is this a bug?
andresuporte
Resolved!
In Truenas Scale, you need to add the folder as a SMB dataset
I deleted the "/mnt/HDD/rede" folder and created a dataset with the same name. It worked
Now, I will have to recreate the subfolders as SMB datasets too, but that's ok
Here's the link to the Truenas Docs that I found (and hadn't read before)
Thank you and good luck everyone!
anodos
Sambassador
Is this a bug?
Oh, you created directories and shared those rather than datasets?
andresuporte
Yep
Using Truenas Core, this is how I shared folders. I create them in batch via the command line, indicated the path to SMB sharing and voilà.
This is the first time I've actually used the Truenas Scale.
I now see that it is necessary to create a SMB dataset one by one and all the subfolders that I want to share. After that, I edit the ACL permissions and everything works, without the initial error message
Rookie mistake. (In the south Brazil, we call it "chupetisse" )
andresuporte
I agree with you, Melonion
Creating datasets for each folder, one by one, makes the work slow and tiring
What I did is not the perfect solution, but it is the way I understood TrueNAS Scale to work
In the Linux world, I worked with Debian and Ubuntu Servers before, always using SMB, and I never experienced this
Anyway, I'll stay tuned for news
