Dual Networks for VM's
JohnnyD
Is it possible to use the second NIC on my MB to serve a second LAN so I can setup VM's for use on the second LAN only, I just tried to add a LAN IP and it seemed to disable access to the GUI on the current LAN IP and non of the current VM's worked like they should, so I removed the second LAN IP.
Also why do I lose access to the existing GUI and also lose all my VM's whenever I configure that second NIC in Scale? I have to reboot the whole machine to regain access and make everything work again
JD
JohnnyD
TY, works on the second LAN on a different subnet fine with no IP in the second NIC
