- May 28, 2011
I have an issue with the drives not spinning down. They use to spin down when I used 8.0.1 but then I upgraded to 8.0.3-MM and they do not spin down.
I have stopped CRON (due to a possible issue keeping the drive up) but that failed also.
I unplugged the network cable thinking maybe something was polling the NAS, but no luck.
I only have MiniDLNA running from the MM set.
I can shut them down manually via "ataidle -S 5 /dev/ada0" for example. They stay down and do not spin back up unless I try to access them.
I have of course rebooted a few times as well. My system has no video card either. I might try installing it just to see if there is a difference but it was out in the previous version I ran and the drives slept fine.
Not sure to do next but would love some advice.
-Mark
-Mark
