Xander May
 - Sep 17, 2014
But this however:
Code:SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error # 1 Extended captive Interrupted (host reset) 90% 139 - # 2 Short captive Interrupted (host reset) 70% 139 - # 3 Extended offline Aborted by host 90% 139 -
...The SMART tests don't finish properly. It is a definite worry to me. If it is user-induced - retry. If not.... something is fishy.
I aborted the very first long test, after that I left it for 4 hours.
Yes, but that's consistent with some other flaky piece of hardware causing the drive to disconnect and reset intermittently, which could also lead to the ZFS checksum errors.
EDIT: for clarity - it could well be the drive itself, but didn't you see trouble on more than one drive?
I saw trouble on two drives. the third seems fine but I havent run any SMART tests on it. Other drives that were fine for months are also now misbehaving. So probably MOBO...
