Having a strange issue on my zpool. If I initiate a scrub, around 15% completion, a random drive drops out then reconnects and ZFS begins to resilver. I've tried replacing the drives with new ones, and swapped controllers, but the issue still occurs. I'm not sure what to do next? There are no reported smart errors.
Here is smartctl -a /dev/da1 (the drive that dropped out)
mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1678 loginfo 31110d00 mpr0: (da1:mpr0:0:1:0): READ(16). CDB: 88 00 00 00 00 05 ef e1 8e d0 00 00 00 60 00 00 Controller reported scsi ioc terminated tgt 1 SMID 1544 loginfo 31110d00 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1032 loginfo 31110d00 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1142 loginfo 31110d00 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1059 loginfo 31110d00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d4 c8 00 00 98 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d4 28 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d5 60 00 03 18 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain (da1:mpr0:0:1:0): READ(16). CDB: 88 00 00 00 00 05 ef e1 8a 80 00 00 00 98 00 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain mpr0: Controller reported scsi ioc terminated tgt 1 SMID 488 loginfo 31170000 mpr0: (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d4 28 00 00 a0 00 Controller reported scsi ioc terminated tgt 1 SMID 629 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1083 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1197 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 2056 loginfo 31170000 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d4 c8 00 00 98 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d5 60 00 03 18 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain (da1:mpr0:0:1:0): READ(16). CDB: 88 00 00 00 00 05 ef e1 8a 80 00 00 00 98 00 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain (da1:mpr0:0:1:0): READ(16). CDB: 88 00 00 00 00 05 ef e1 8e d0 00 00 00 60 00 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1112 loginfo 31170000 mpr0: (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d4 28 00 00 a0 00 Controller reported scsi ioc terminated tgt 1 SMID 1326 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 802 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1629 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1410 loginfo 31170000 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d4 c8 00 00 98 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a 0e d5 60 00 03 18 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain (da1:mpr0:0:1:0): READ(16). CDB: 88 00 00 00 00 05 ef e1 8a 80 00 00 00 98 00 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain (da1:mpr0:0:1:0): READ(16). CDB: 88 00 00 00 00 05 ef e1 8e d0 00 00 00 60 00 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain mpr0: mprsas_prepare_remove: Sending reset for target ID 1 da1 at mpr0 bus 0 scbus9 target 1 lun 0 da1: <ATA ST16000NM001G-2K SN03> s/n ZL297N6W detached mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1974 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 2030 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 535 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1678 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 237 loginfo 31130000 departing mpr0: No pending commands: starting remove_device mpr0: clearing target 1 handle 0x001c mpr0: At enclosure level 0, slot 1, connector name ( ) mpr0: Unfreezing devq for target ID 1 (da1:mpr0:0:1:0): Periph destroyed mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x001c> enclosureHandle<0x0001> slot 1 mpr0: At enclosure level 0 and connector name ( ) da1 at mpr0 bus 0 scbus9 target 1 lun 0 da1: <ATA ST16000NM001G-2K SN03> Fixed Direct Access SPC-4 SCSI device da1: Serial Number ZL297N6W da1: 600.000MB/s transfers da1: Command Queueing enabled da1: 15259648MB (31251759104 512 byte sectors) mpr0: Controller reported scsi ioc terminated tgt 1 SMID 959 loginfo 31110d00 mpr0: (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 65 70 00 00 a0 00 Controller reported scsi ioc terminated tgt 1 SMID 510 loginfo 31110d00 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1722 loginfo 31110d00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 66 10 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 64 d0 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 3 more tries remain mpr0: Controller reported scsi ioc terminated tgt 1 SMID 930 loginfo 31170000 mpr0: (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 64 d0 00 00 a0 00 Controller reported scsi ioc terminated tgt 1 SMID 280 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1330 loginfo 31170000 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 65 70 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 66 10 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 2 more tries remain mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1670 loginfo 31170000 mpr0: (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 64 d0 00 00 a0 00 Controller reported scsi ioc terminated tgt 1 SMID 940 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1737 loginfo 31170000 mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1334 loginfo 31170000 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 65 70 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain (da1:mpr0:0:1:0): READ(10). CDB: 28 00 2a aa 66 10 00 00 a0 00 (da1:mpr0:0:1:0): CAM status: CCB request completed with an error (da1:mpr0:0:1:0): Retrying command, 1 more tries remain mpr0: mprsas_prepare_remove: Sending reset for target ID 1 da1 at mpr0 bus 0 scbus9 target 1 lun 0 da1: <ATA ST16000NM001G-2K SN03> s/n ZL297N6W detached mpr0: Controller reported scsi ioc terminated tgt 1 SMID 746 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 130 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1449 loginfo 31130000 departing mpr0: Controller reported scsi ioc terminated tgt 1 SMID 1746 loginfo 31130000 departing mpr0: No pending commands: starting remove_device mpr0: clearing target 1 handle 0x001c mpr0: At enclosure level 0, slot 1, connector name ( ) mpr0: Unfreezing devq for target ID 1 (da1:mpr0:0:1:0): Periph destroyed mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x001c> enclosureHandle<0x0001> slot 1 mpr0: At enclosure level 0 and connector name ( ) da1 at mpr0 bus 0 scbus9 target 1 lun 0 da1: <ATA ST16000NM001G-2K SN03> Fixed Direct Access SPC-4 SCSI device da1: Serial Number ZL297N6W da1: 600.000MB/s transfers da1: Command Queueing enabled da1: 15259648MB (31251759104 512 byte sectors)
errors: No known data errors
pool: terapool
state: ONLINE
scan: resilvered 216M in 00:01:25 with 0 errors on Sun Mar 14 13:03:36 2021
NAME STATE READ WRITE CKSUM
terapool ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/295eaade-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/330a28cd-ebce-dc4d-a68d-a373239c0ac5 ONLINE 0 0 0
gptid/2290e748-ff5a-b54b-bb34-c306ea21e8fa ONLINE 0 0 0
gptid/141da3e0-ff50-4f9e-b0ff-156574350b3c ONLINE 0 0 0
gptid/2fe281ae-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/30621220-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/337369ad-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/482fcedf-0716-41b6-9c0b-d7e8db8444a5 ONLINE 0 0 0
gptid/34487cb9-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/35beca93-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/3725335a-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/39d17383-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/3a55cf88-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/3ba25374-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/3c9a1e04-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
raidz2-3 ONLINE 0 0 0
gptid/d7a546dd-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/b6b95789-baac-4b33-b69f-8b5b01b60c5d ONLINE 0 0 0
gptid/de8f5473-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/dfa46229-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/dba95b5c-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e0e414d1-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e2f620e3-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e2e746c7-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e5c7d0c7-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e723e2e9-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e65e915e-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/e64f9c2d-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/ea523ac8-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/eade446f-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
gptid/ec017d8a-eec5-11ea-93c6-3cecef6e7f4c ONLINE 0 0 0
special
mirror-1 ONLINE 0 0 0
gptid/54ce329f-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/54d84cd3-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/60c6091b-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
gptid/60c06ae1-ebf1-11ea-994d-3cecef6bac28 ONLINE 0 0 0
logs
nvd4p1 ONLINE 0 0 0
cache
nvd5p1 ONLINE 0 0 0
nvd3p1 ONLINE 0 0 0
nvd6p1 ONLINE 0 0 0
nvd2p1 ONLINE 0 0 0
errors: No known data errorsHere is smartctl -a /dev/da1 (the drive that dropped out)
root@teracube[/mnt/datapool/adam]# smartctl -a /dev/da1
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST16000NM001G-2KK103
Serial Number: ZL297N6W
LU WWN Device Id: 5 000c50 0c7409f95
Firmware Version: SN03
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Mar 14 13:08:53 2021 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1456) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 081 064 044 Pre-fail Always - 118866536
3 Spin_Up_Time 0x0003 094 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 11
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 083 060 045 Pre-fail Always - 193090397
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1680
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 11
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 058 051 040 Old_age Always - 42 (Min/Max 42/43)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 98
194 Temperature_Celsius 0x0022 042 049 000 Old_age Always - 42 (0 22 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1675 (47 5 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 49014624841
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 327664310264
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 1669 -
# 2 Short offline Completed without error 00% 1644 -
# 3 Short offline Completed without error 00% 1621 -
# 4 Short offline Completed without error 00% 1597 -
# 5 Short offline Completed without error 00% 1573 -
# 6 Short offline Completed without error 00% 1549 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
