Drive Temps
Samuel Tai
  1. Make sure the SMART service is enabled and running under Services.
  2. Make sure your drives under Storage->Disks are enabled for SMART. This has to be done per disk via the Edit button.
  3. Then, you'll be able to see temps in Reporting. Select the Disk report (pull down from CPU), select the disks from the Devices pulldown, and select Disk Temperature from the Metrics pulldown.
