My System:
The Problem:
On the weekend, i moved from Unraid to Truenas Scale. I put all my data from my Backup back on the Array.
Overnight i did a Scrub Tasks.
In the morning, I saw a few massages via Telegram:
And this was the array status:
The one drive with no errors was the missing one.
After that, i did a restart of the system. The drive was back online and the System did a resilver.
That one drive did still have errors so i removed it from the array and checked with smart. Looks ok to me so i quick format the drive and put it back in. It resilvers again but the drive(s) still gets errors?
Not sure whats up with that in unraid i did not have any problems with the drives?
SMART:
			- Motherboard: Gigabyte B760 Gaming X AX DDR4
 - CPU: Intel Core I5 13500
 - RAM: Corsair Vengeance LPX 32GB (2 x 16 GB) DDR4 3200MHz
 - Hard drives, quantity, model numbers, and RAID configuration, including boot drives:
4x ST8000DMZ04 1x ST8000VNZ04 RAIDZ1 - Hard disk controllers: Adaptec ASR-72405
 - Network cards: onboard from MB
The Problem:
HomeServer01, [20.03.2023 00:00]
TrueNAS @ HomeServer01
New alerts:
  * Scrub of pool 'Array1_32TB' started.
Current alerts:
HomeServer01, [20.03.2023 00:04]
New alerts:
  * Pool Array1_32TB state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
Current alerts:
HomeServer01, [20.03.2023 00:05]
New alert:
  * Pool Array1_32TB state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The following devices are not healthy:
    * Disk ST8000DM004-2U9188 WSC**** is REMOVED
The following alert has been cleared:
Current alerts:
HomeServer01, [20.03.2023 00:52]
New alerts:
  * Scrub of pool 'Array1_32TB' finished.
Current alerts:
HomeServer01, [20.03.2023 00:53]
New alert:
  * Pool Array1_32TB state is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Current alerts:
    * Disk ST8000DM004-2U9188 WSC**** is REMOVEDAfter that, i did a restart of the system. The drive was back online and the System did a resilver.
SMART:
smartctl -a /dev/sdl
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Model Family:     Seagate BarraCuda 3.5 (SMR)
Device Model:     ST8000DM004-2U9188
Serial Number:
LU WWN Device Id: 5 000c50 0df81a45e
Add. Product Id:  DELL(tm)
Firmware Version: 0001
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Mar 20 12:09:22 2023 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 974) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   006    Pre-fail  Always       -       173954785
  3 Spin_Up_Time            0x0003   097   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       558
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   089   060   045    Pre-fail  Always       -       761297024
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       12840h+30m+46.447s
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       168
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   068   055   040    Old_age   Always       -       32 (Min/Max 32/33)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       116
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1880
194 Temperature_Celsius     0x0022   032   045   000    Old_age   Always       -       32 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   082   064   000    Old_age   Always       -       173954785
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       8786h+17m+11.597s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       51032138593
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       437887931800
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     12804         -
