Fastline
 - Jul 7, 2023
Yes, that lanes thing was not clear to me. But its all good now. I don't think you lack in whatever skills you have :) Thanks to you too as well :)…which is pretty much the information you could not find. The open question is whether I'm lacking in paedagogic skills and/or whether you're lacking in listening skills.
I can see the difference now. Thank you again for brining it to my attention. So, a high point 1120 or 1180 would work fine here instead of the Tri-Mode HBA I guess?If you're not using the convenience of a backplane, it has been suggested quite a few times up-thread to either connect the drives to PCIe slots, using bifurcation and suitable adapters, or to use an add-in card with a PLX switch. (The backplane relies itself on bifurcation.)
There was also a link to actual tests showing the consequences of using a Tri-Mode HBA vs. directly attached drives: Namely, the HBA works fine until it doesn't, latency goes up badly and total throughput quickly hits a hard limit from there, while directly attached drives keep on scaling up, reaching a distinctly higher maximal throughput than the HBA, at a distinctly lower latency.
Also, am I good with the SATA SSD on the HBA or does that too require some kind of dedicated AIC?
