Drive or HBS issues?
platinumjsi
Ok so a little background, I have added 2x 2tb WD reds to my Freenas server in a mirrored pair to use for downloads, Sickbeard / couchpotato ect.
I needed more ports and a short card so I added in a Highpoint 640L card.
Now on boot FreeNas keeps reporting that Device ADA1 is faulty, for a time it did report ADA0 as well but since I changed the SATA cables ADA0 is not showing up now as faulty.
So this is what I get on boot :
Feb 16 09:18:46 freenas notifier: dd: /dev/ada1: short write on character device
Feb 16 09:18:46 freenas notifier: dd: /dev/ada1: end of device
Feb 16 09:18:46 freenas notifier: 33+0 records in
Feb 16 09:18:46 freenas notifier: 32+1 records out
Feb 16 09:18:46 freenas notifier: 33644544 bytes transferred in 0.543754 secs (61874557 bytes/sec)
Feb 16 09:19:00 freenas GEOM_ELI: Device ada1p1.eli created.
Feb 16 09:19:00 freenas GEOM_ELI: Encryption: AES-XTS 128
Feb 16 09:19:00 freenas GEOM_ELI: Crypto: software
Feb 16 09:19:01 freenas notifier: Stopping smartd.
Feb 16 09:19:01 freenas notifier: smartd not running? (check /var/run/smartd.pid).
Feb 16 09:19:01 freenas notifier: Starting smartd.
Feb 16 09:19:03 freenas smartd[10222]: Device: /dev/ada1, FAILED SMART self-check. BACK UP DATA NOW!
I replaced the drive with another WD Red I had and afgter resilvering its still saying ADA1 is faulty so thats making me think the drives are fine?
Running Smartctl on the replacment drive shows the drive looks fine (forgot to smart data from the old drive but it passed a few smart long / short tests :
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 184 173 021 Pre-fail Always - 3775
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1659
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 11750
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 350
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 265
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1393
194 Temperature_Celsius 0x0022 119 106 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
Only thing I have not done yet is try the other two ports on the controller (Going to try that later)
Any thoughts though?, I am scratching my head as to what FreeNas is picking up as a major issue with the drive.
Thanks in advance guys.
platinumjsi
I would also note the 2tb drives are from a old array and have been sat for about 6 months, I am thinking this might be the issue? the drives spin up fine however (No noise) and files transfer over as quick as expected.
platinumjsi
Ok so swapped ports on the SATA card and now after boot no errors!
I should run more tests on the card / perhaps RMA it but as I dont need more than 2 ports I am inclined to now leave it.
