drive offline but no member disk listed for replacement
theaddies
I have a 10 x 2TB RAIDZ2 pool and I had a drive in my pool fail, ada8. I swapped out the failed drive for a new one. Now when I go to replace disk the "member disk" list is blank. The disk I need to replace is ada8, but it is not listed. I don't know what to do from here.
  • zpoolstatus.txt
  • camcontrol.txt
Redcoat
Bikerchris
I'd normally add the replacement drive to the machine, then select the faulty drive and replace. Then once complete, remove the faulty drive.
theaddies
I wish I had done that. Perhaps I can go backwards. I will try. I am out of SATA ports but I could put it on USB3 and then move it to SATA after removing the bad drive.
theaddies
I get the error below. I thought I might be able to replicate the drive even though it is degraded but I cannot.
libzfs.ZFSException: pool I/O is currently suspended
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 277, in replace
target.replace(newvdev)
File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 2060, in libzfs.ZFSVdev.replace
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 111, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 279, in replace
raise CallError(str(e), e.code)
middlewared.service_exception.CallError: [EZFS_POOLUNAVAIL] pool I/O is currently suspended
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 122, in replace
raise e
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 102, in replace
await self.middleware.call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1221, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1227, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1154, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
theaddies
I don't really know what I did, but I rebooted and it has now resilvered and appears to work.
Bikerchris
Don't beat yourself up about it, there's lots of 'wish I had dones' with my config too. If possible and for reliability, get a LSI HBA instead. Or if you've got more than one pool, perhaps disconnect (not delete of course) and use one of those spare ports.
Anyhow, I see it's re-silvering, very glad to hear it.
