Drive not recognized
urobe
Hey there,
I tried to replace a disk in a system, but the drive isn't recognized. This is the output I get, when the drive is added to the live system:
Mar  1 16:36:44 nas kernel: mpt2sas_cm0: handle(0x16) sas_address(0x5003048000e3fbd8) port_type(0x1)
Mar  1 16:36:46 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:36:48 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:36:51 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:36:51 nas kernel:  end_device-0:0:26: add: handle(0x0016), sas_addr(0x5003048000e3fbd8)
Mar  1 16:36:51 nas kernel: mpt2sas_cm0: mpt3sas_transport_port_remove: removed: sas_addr(0x5003048000e3fbd8)
Mar  1 16:36:51 nas kernel: mpt2sas_cm0: removing handle(0x0016), sas_addr(0x5003048000e3fbd8)
Mar  1 16:36:51 nas kernel: mpt2sas_cm0: enclosure logical id(0x500304800000007f), slot(12)
Mar  1 16:36:51 nas kernel: mpt2sas_cm0: handle(0x16) sas_address(0x5003048000e3fbd8) port_type(0x1)
Mar  1 16:36:53 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:36:55 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:36:57 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:37:00 nas kernel: mpt2sas_cm0: log_info(0x31111000): originator(PL), code(0x11), sub_code(0x1000)
Mar  1 16:37:00 nas kernel:  end_device-0:0:27: add: handle(0x0016), sas_addr(0x5003048000e3fbd8)
Mar  1 16:37:00 nas kernel: mpt2sas_cm0: mpt3sas_transport_port_remove: removed: sas_addr(0x5003048000e3fbd8)
Mar  1 16:37:00 nas kernel: mpt2sas_cm0: removing handle(0x0016), sas_addr(0x5003048000e3fbd8)
Mar  1 16:37:00 nas kernel: mpt2sas_cm0: enclosure logical id(0x500304800000007f), slot(12)
I do have six more drives of the same size and make in the same system, that are recognized just fine.
any hint or help is greatly appreciated!
-Tobi
urobe
I tried 3 different slots and no led ever lights up.
Samuel Tai
Sounds like the drive electronics may be damaged. I would just replace it with another unit.
urobe
i tried it on my second truenas, same behavior. Later I put it in a desktop with stright sata wire to the board. If it's not seen there, I#ll send it back.
