ttommy
- Jan 4, 2017
Hi all,
it seems that I have a failing drive? And I would like to ask for your advice on the safest way to proceed.
A new drive is on the way but it will take 3 days. Is it safer to turn off the server or keep it running until the drive arrives?
Help is much appreciated. In the following further information (let me know if there is any more info needed):
I received following alert and noticed that read/write access on the network drives are very slow now:
running:
zpool status
running:
smartctl -t long /dev/ada3 (estimation was that it should take 700mins)
smartctl -a /dev/ada3 (I accidently aborted it after half a day)
CRITICAL Device: /dev/ada3, Self-Test Log error count increased from 0 to 1.
running:
zpool status
pool: nasdata0 state: ONLINE scan: scrub repaired 0 in 0 days 09:32:42 with 0 errors on Sun Jan 9 09:32:43 2022 config: NAME STATE READ WRITE CKSUM nasdata0 ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/fa24bf44-2780-11e7-b83f-1c98ec0e86cc ONLINE 0 0 0 gptid/fac6b6d3-2780-11e7-b83f-1c98ec0e86cc ONLINE 0 0 0 mirror-1 ONLINE 0 0 0 gptid/fb70c825-2780-11e7-b83f-1c98ec0e86cc ONLINE 0 0 0 gptid/f9718802-8394-11e8-a1d5-1c98ec0e86cc ONLINE 0 0 0 errors: No known data errors
running:
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p14 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68L0BN1 Serial Number: WD-WXB1HB4M4USZ LU WWN Device Id: 5 0014ee 2b7f72650 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri Feb 11 21:28:50 2022 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 120) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: ( 4604) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 700) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 233 198 021 Pre-fail Always - 7316 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 88 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 001 001 000 Old_age Always - 65535 9 Power_On_Hours 0x0032 042 042 000 Old_age Always - 43031 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 88 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 8 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 573 194 Temperature_Celsius 0x0022 117 109 000 Old_age Always - 35 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 2 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 80% 43012 646572264 # 2 Extended offline Aborted by host 90% 43005 - # 3 Short offline Completed without error 00% 43005 - # 4 Extended offline Completed: read failure 90% 42919 1166801824 # 5 Extended offline Completed without error 00% 42691 - # 6 Extended offline Completed without error 00% 42523 - # 7 Extended offline Completed without error 00% 42355 - # 8 Extended offline Completed without error 00% 42188 - # 9 Extended offline Completed without error 00% 41948 - #10 Extended offline Completed without error 00% 41780 - #11 Extended offline Completed without error 00% 41612 - #12 Extended offline Completed without error 00% 41444 - #13 Extended offline Completed without error 00% 41236 - #14 Extended offline Completed without error 00% 41061 - #15 Extended offline Completed without error 00% 40726 - #16 Extended offline Completed without error 00% 40484 - #17 Extended offline Completed without error 00% 40317 - #18 Extended offline Completed without error 00% 40149 - #19 Extended offline Completed without error 00% 39981 - #20 Extended offline Completed without error 00% 39765 - #21 Extended offline Completed without error 00% 39597 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
FreeNAS-11.3-U5
HP Microserver Gen8
4x 6TB WD Red EFRX
Xeon E3-1220L V5 2.30GHz, 16GB RAM
HP Microserver Gen8
4x 6TB WD Red EFRX
