Hi there
Since OpenZFS version 2.1 there has been support for dRAID, and it is possible to create a dRAID pool from the command line with TrueNAS Scale.
In my setup with 18TB disks I really like the idea of dRAID faster resilver times compared to regular raidz.
(yes I know that someone will tell me that mirrors or small raidz is the way to go, but still I like dRAID better)
Yet my manually created dRAID it is not recognized as a zpool by the GUI... I tried to export it from the command line, and was able to import it via the GUI, yet it is shown as a "FILESYSTEM" type... I was able to create datasets etc..
I then tried the bleeding edge 22.12 Beta 1, but sadly same issue here.
Can anyone tell me if/when dRAID will be supported in the GUI?
And is this just cosmetics? Or are there other aspects of TrueNAS that will be broken because TrueNAS doesn't see the pool corectly?
A plan could be to just run the stable version of TrueNAS Scale, and live with the "broken" GUI, and wait for support in the GUI?
/B
/B
