MajorKhanage
 - Oct 20, 2023
Hi there,
Does anyone have the Dropbox cloud sync successfully working? I cannot get it to work for more than a few hours; after which I get the error "expired_access_token".
I went to "Add" credentials to "Cloud Credentials" and selected Dropbox.
Attempt 1:
Attempt 2:
What am I supposed to do to get this integration to work? Help appreciated. I can't find any recent info on the forum about it, since Dropbox went to short-lived tokens a few years ago. The official documentation also doesn't really go into any details as far as I can find.
Thanks,
Marc
{Happy to provide my setup details if required, but felt it's not particularly relevant to this issue}
Attempt 1:
- I created a App on Dropbox, with relevant permissions etc
 - Populate OAuth Client ID, OAuth Client Secret and Token in TrueNAS
 - Tested connection
 - Created "Cloud Sync Task"
Attempt 2:
- I went to "Add" credentials to "Cloud Credentials" and selected Dropbox
 - Clicked "Log In To Provider"
 - A pop-up appeared and I allowed Dropbox access etc (Message: "Only proceed if you are setting up cloud sync on your TrueNAS system at https://{local TrueNAS ip address}/ui/credentials/backup-credentials")
 - Pop-up closed and no credentials were populated anywhere
 - I can see a new app in Dropbox called "TrueNAS CloudSync"
Thanks,
Marc
