Document Management Software
Peacebrother
I'm looking for an DMS Server for my FreeNas Box.
I found some Information about LogicalDoc. But nothing about an installation on a FreeBSD system. Is it possible to run the software on my machine?
Or does anyone know an alternative software?
Thanks
Abigail111
HI there
I have tried a free trial from a document management software recently.And it turns out to be powerful encough.You can have a try.But it is a little bit expensive for me.So
if there is a cheap document management software.I'd also like to have a try.Hope to help you.
