- Apr 16, 2020
Because it works properly. Its repeatable (I use portainer and stacks) but docker with compose files would be just as good.Between the two can you elaborate on why you prefer 3 so far?
Because it doesn't have a routing bug that points all traffic from a container to the LAN at the default gateway and lets the gateway send it back to the LAN. There are workarounds - but I do not like the bug - it offends me.
I no longer use a VM to run portainer / docker. Why - because the VM essentially dedicated hardware to the job where with jailmaker I have can share access to the host CPU & Memory although as a consequence I have had to limit tdarr to a number of CPU's.
@Kailee71 has the right of it
