Docker Containers crash (seemingly) randomly
CookiesMonster
sdb and sdb1 are showing up now (see photo). I'm on Step 4 of your steps. It's asking for "First Sector". I'm not sure what that means. You mentioned the partition size but I just wanted to be sure.
I created the partition of 16GB (see photo). According to your step 6, which is mkswap -L RANCHER_SWAP /dev/sdb1, except I don't have an sdb1. The one I just created is sdb19 (see photo).
Is this the one I should be calling out?
Samuel Tai
Ah, you got it wrong. Run the fdisk again, and use partition number 1 instead of 19. The start and stops can be the same.
Samuel Tai
Did you run the mkswap already? If so, yes, you can run the ros config set.
Samuel Tai
Done. How do I check to know it worked?
If you run fdisk /dev/sdb, and then p inside fdisk, this will display the partition table. If partition 1 shows Linux swap as the type, you're good.
Samuel Tai
After you create the mount, restart the VM. When it's back up, run free -m or swapon -s to see if you have swap active.
CookiesMonster
Here is the output of fdisk /dev/sdb, then p
I don't see anything about it being a SWAP partition.
Samuel Tai
Run the mkswap again.
CookiesMonster
I still get the same output after I ran the mkswap line again.
I noticed in your Step 4 you say "Type n to create a new partition. In your case, you want 19, a Linux swap partition. "
I never saw a prompt to set something to "19".
Was that some value I was supposed to set?
Samuel Tai
Sorry. In fdisk, use option t to change the type of partition 1. Select partition 1, and then use type 19 for Linux swap.
CookiesMonster
I think that fixed the partition type (see photo).
Now I restart the VM and use free -m or swapon -s to see if swap is active?
Samuel Tai
First, mkswap again to make sure. Then ros config export to make sure the mount is in place. Then you can restart the VM.
CookiesMonster
Here's what I get from ros config export .
Does this look OK?
Samuel Tai
Yes, that looks good.
