Hi, I need the help/advice of this great community again.
After the crashes, I had with TrueNAS - https://www.truenas.com/community/threads/sos-kernel-panic-help.104524
I decided (And they recommended me) to upgrade the hardware and reinstall TrueNAS on the new hardware and everything works great, very stable!
Except for one problem that I already knew about...
So among all the crashes, I had with my previous TrueNAS I also started getting files corruption mainly when I did a scrub
It's scary to see this, but I was sure at the time it was because of all the crashes so luckily I had a backup of them I just restored the same files from the backup and that's it (mostly it was one file or the ZFS would just manage to solve it by itself without files corruption I would just get a CKSUM error and Applications are unaffected.)
Now that I rebuilt my TrueNAS and reinstalled it - I just took the same drives and the previous pool with me.
Every time I do Scrub I get these errors - sometimes "Applications are unaffected" and sometimes there really is file corruption and then I have to restore these files from a backup.
Now, what should I do? From my previous post - on the crashes. I was told that I would have to rebuild the pool. jgreco reply
I'm asking to make sure this is really what I need to do to solve it and there is no other way. Before I buy a drive to have somewhere to move the data while I rebuild the pool.
And if this is really what I need to do (rebuild the pool) what is the best way to move everything to another pool in TrueNAS? Simply make a snapshot for the entire existing pool and then use the replication task to perform the transfer. Or is there a better and safer way?
I hope I was clear and didn't confuse you with what is going on here.
See replies 5 and 6
Thanks in advance, waiting for your reply!
See replies 5 and 6
