I've got a new setup running within ESXI 6.5 and have my HBA passing through to Freenas.
Everything appears to be working as intended (although for some reason I can't make use of my Intel PRO 1000 quad port card!).
On reboot I get the following error "dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused"
Any help appreciated! Below is my complete log from reboot.
Cheers!
Cheers!
Feb 16 00:00:00 nas newsyslog[12002]: logfile turned over due to size>100K Feb 16 00:00:00 nas syslog-ng[1422]: Configuration reload request received, reloading configuration; Feb 16 20:46:44 nas notifier: Stopping nginx. Feb 16 20:46:44 nas notifier: Waiting for PIDS: 2633. Feb 16 20:46:47 nas notifier: shutdown: [pid 52635] Feb 16 20:46:47 nas notifier: Shutdown NOW! Feb 16 20:46:47 nas shutdown: reboot by root: Feb 16 20:46:47 nas notifier: Shutdown NOW! Feb 16 20:46:47 nas notifier: Feb 16 20:46:47 nas notifier: System shutdown time has arrived^G^G Feb 16 20:46:47 nas smbd: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function Feb 16 20:46:48 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Feb 16 20:46:48 nas ntpd[1852]: ntpd exiting on signal 15 (Terminated) Feb 16 20:46:49 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Feb 16 20:46:50 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Feb 16 20:46:51 nas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Feb 16 20:46:52 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Feb 16 20:46:53 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Feb 16 20:46:54 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Feb 16 20:46:55 nas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Feb 16 20:46:56 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Feb 16 20:46:58 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Feb 16 20:46:59 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Feb 16 20:47:00 nas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Feb 16 20:47:01 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Feb 16 20:47:02 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Feb 16 20:47:03 nas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Feb 16 20:47:04 nas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Feb 16 20:47:04 nas syslog-ng[1422]: syslog-ng shutting down; version='3.6.4' Feb 16 20:48:19 nas syslog-ng[1421]: syslog-ng starting up; version='3.6.4' Feb 16 20:48:19 nas Waiting (max 60 seconds) for system process `vnlru' to stop...done Feb 16 20:48:19 nas Waiting (max 60 seconds) for system process `bufdaemon' to stop...done Feb 16 20:48:19 nas Waiting (max 60 seconds) for system process `syncer' to stop... Feb 16 20:48:19 nas Syncing disks, vnodes remaining...0 0 0 0 0 0 done Feb 16 20:48:19 nas All buffers synced. Feb 16 20:48:19 nas GEOM_ELI: Device da0p1.eli destroyed. Feb 16 20:48:19 nas GEOM_ELI: Detached da0p1.eli on last close. Feb 16 20:48:19 nas GEOM_ELI: Device da1p1.eli destroyed. Feb 16 20:48:19 nas GEOM_ELI: Detached da1p1.eli on last close. Feb 16 20:48:19 nas GEOM_ELI: Device da2p1.eli destroyed. Feb 16 20:48:19 nas GEOM_ELI: Detached da2p1.eli on last close. Feb 16 20:48:19 nas GEOM_ELI: Device da3p1.eli destroyed. Feb 16 20:48:19 nas GEOM_ELI: Detached da3p1.eli on last close. Feb 16 20:48:19 nas GEOM_ELI: Device da4p1.eli destroyed. Feb 16 20:48:19 nas GEOM_ELI: Detached da4p1.eli on last close. Feb 16 20:48:19 nas Uptime: 22h53m1s Feb 16 20:48:19 nas GEOM_ELI: Device da5p1.eli destroyed. Feb 16 20:48:19 nas GEOM_ELI: Detached da5p1.eli on last close. Feb 16 20:48:19 nas Copyright (c) 1992-2016 The FreeBSD Project. Feb 16 20:48:19 nas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 Feb 16 20:48:19 nas The Regents of the University of California. All rights reserved. Feb 16 20:48:19 nas FreeBSD is a registered trademark of The FreeBSD Foundation. Feb 16 20:48:19 nas FreeBSD 10.3-STABLE #0 r295946+1805185(9.10.2-STABLE): Wed Jan 11 17:12:42 UTC 2017 Feb 16 20:48:19 nas root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64 Feb 16 20:48:19 nas FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512 Feb 16 20:48:19 nas CPU: Intel(R) Xeon(R) CPU E31240 @ 3.30GHz (3292.52-MHz K8-class CPU) Feb 16 20:48:19 nas Origin="GenuineIntel" Id=0x206a7 Family=0x6 Model=0x2a Stepping=7 Feb 16 20:48:19 nas Features=0xfa3fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,DTS,MMX,FXSR,SSE,SSE2,SS> Feb 16 20:48:19 nas Features2=0x9fba2203<SSE3,PCLMULQDQ,SSSE3,CX16,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,HV> Feb 16 20:48:19 nas AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> Feb 16 20:48:19 nas AMD Features2=0x1<LAHF> Feb 16 20:48:19 nas Structured Extended Features=0x2<TSCADJ> Feb 16 20:48:19 nas TSC: P-state invariant Feb 16 20:48:19 nas Hypervisor: Origin = "VMwareVMware" Feb 16 20:48:19 nas real memory = 9663676416 (9216 MB) Feb 16 20:48:19 nas avail memory = 8257908736 (7875 MB) Feb 16 20:48:19 nas Event timer "LAPIC" quality 600 Feb 16 20:48:19 nas ACPI APIC Table: <PTLTD APIC > Feb 16 20:48:19 nas FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs Feb 16 20:48:19 nas FreeBSD/SMP: 2 package(s) x 1 core(s) Feb 16 20:48:19 nas cpu0 (BSP): APIC ID: 0 Feb 16 20:48:19 nas cpu1 (AP): APIC ID: 2 Feb 16 20:48:19 nas random: <Software, Yarrow> initialized Feb 16 20:48:19 nas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. Feb 16 20:48:19 nas MADT: Forcing active-low polarity and level trigger for SCI Feb 16 20:48:19 nas ioapic0 <Version 1.1> irqs 0-23 on motherboard Feb 16 20:48:19 nas kbd1 at kbdmux0 Feb 16 20:48:19 nas aesni0: <AES-CBC,AES-XTS> on motherboard Feb 16 20:48:19 nas padlock0: No ACE support. Feb 16 20:48:19 nas cryptosoft0: <software crypto> on motherboard Feb 16 20:48:19 nas acpi0: <INTEL 440BX> on motherboard Feb 16 20:48:19 nas acpi0: Power Button (fixed) Feb 16 20:48:19 nas Timecounter "HPET" frequency 14318180 Hz quality 950 Feb 16 20:48:19 nas cpu0: <ACPI CPU> on acpi0 Feb 16 20:48:19 nas cpu1: <ACPI CPU> on acpi0 Feb 16 20:48:19 nas attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0 Feb 16 20:48:19 nas Timecounter "i8254" frequency 1193182 Hz quality 0 Feb 16 20:48:19 nas Event timer "i8254" frequency 1193182 Hz quality 100 Feb 16 20:48:19 nas atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0 Feb 16 20:48:19 nas Event timer "RTC" frequency 32768 Hz quality 0 Feb 16 20:48:19 nas Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 Feb 16 20:48:19 nas acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0 Feb 16 20:48:19 nas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 Feb 16 20:48:19 nas pci0: <ACPI PCI bus> on pcib0 Feb 16 20:48:19 nas pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0 Feb 16 20:48:19 nas pci1: <ACPI PCI bus> on pcib1 Feb 16 20:48:19 nas isab0: <PCI-ISA bridge> at device 7.0 on pci0 Feb 16 20:48:19 nas isa0: <ISA bus> on isab0 Feb 16 20:48:19 nas atapci0: <Intel PIIX4 UDMA33 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x1060-0x106f at device 7.1 on pci0 Feb 16 20:48:19 nas ata0: <ATA channel> at channel 0 on atapci0 Feb 16 20:48:19 nas ata1: <ATA channel> at channel 1 on atapci0 Feb 16 20:48:19 nas pci0: <bridge> at device 7.3 (no driver attached) Feb 16 20:48:19 nas vgapci0: <VGA-compatible display> port 0x1070-0x107f mem 0xe8000000-0xefffffff,0xfe000000-0xfe7fffff irq 16 at device 15.0 on pci0 Feb 16 20:48:19 nas vgapci0: Boot video device Feb 16 20:48:19 nas mpt0: <LSILogic 1030 Ultra4 Adapter> port 0x1400-0x14ff mem 0xfeba0000-0xfebbffff,0xfebc0000-0xfebdffff irq 17 at device 16.0 on pci0 Feb 16 20:48:19 nas mpt0: MPI Version=1.2.0.0 Feb 16 20:48:19 nas pcib2: <ACPI PCI-PCI bridge> at device 17.0 on pci0 Feb 16 20:48:19 nas pci2: <ACPI PCI bus> on pcib2 Feb 16 20:48:19 nas uhci0: <UHCI (generic) USB controller> port 0x2040-0x205f irq 18 at device 0.0 on pci2 Feb 16 20:48:19 nas usbus0 on uhci0 Feb 16 20:48:19 nas em0: <Intel(R) PRO/1000 Legacy Network Connection 1.1.0> port 0x2000-0x203f mem 0xfd5c0000-0xfd5dffff,0xfdff0000-0xfdffffff irq 19 at device 1.0 on pci2 Feb 16 20:48:19 nas em0: Ethernet address: 00:0c:29:8e:85:94 Feb 16 20:48:19 nas ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfd5ef000-0xfd5effff irq 16 at device 2.0 on pci2 Feb 16 20:48:19 nas usbus1: EHCI version 1.0 Feb 16 20:48:19 nas usbus1 on ehci0 Feb 16 20:48:19 nas ahci0: <AHCI SATA controller> mem 0xfd5ee000-0xfd5eefff irq 18 at device 4.0 on pci2 Feb 16 20:48:19 nas ahci0: AHCI v1.30 with 30 6Gbps ports, Port Multiplier not supported Feb 16 20:48:19 nas ahcich0: <AHCI channel> at channel 0 on ahci0 Feb 16 20:48:19 nas ahcich1: <AHCI channel> at channel 1 on ahci0 Feb 16 20:48:19 nas ahcich2: <AHCI channel> at channel 2 on ahci0 Feb 16 20:48:19 nas ahcich3: <AHCI channel> at channel 3 on ahci0 Feb 16 20:48:19 nas ahcich4: <AHCI channel> at channel 4 on ahci0 Feb 16 20:48:19 nas ahcich5: <AHCI channel> at channel 5 on ahci0 Feb 16 20:48:19 nas ahcich6: <AHCI channel> at channel 6 on ahci0 Feb 16 20:48:19 nas ahcich7: <AHCI channel> at channel 7 on ahci0 Feb 16 20:48:19 nas ahcich8: <AHCI channel> at channel 8 on ahci0 Feb 16 20:48:19 nas ahcich9: <AHCI channel> at channel 9 on ahci0 Feb 16 20:48:19 nas ahcich10: <AHCI channel> at channel 10 on ahci0 Feb 16 20:48:19 nas ahcich11: <AHCI channel> at channel 11 on ahci0 Feb 16 20:48:19 nas ahcich12: <AHCI channel> at channel 12 on ahci0 Feb 16 20:48:19 nas ahcich13: <AHCI channel> at channel 13 on ahci0 Feb 16 20:48:19 nas ahcich14: <AHCI channel> at channel 14 on ahci0 Feb 16 20:48:19 nas ahcich15: <AHCI channel> at channel 15 on ahci0 Feb 16 20:48:19 nas ahcich16: <AHCI channel> at channel 16 on ahci0 Feb 16 20:48:19 nas ahcich17: <AHCI channel> at channel 17 on ahci0 Feb 16 20:48:19 nas ahcich18: <AHCI channel> at channel 18 on ahci0 Feb 16 20:48:19 nas ahcich19: <AHCI channel> at channel 19 on ahci0 Feb 16 20:48:19 nas ahcich20: <AHCI channel> at channel 20 on ahci0 Feb 16 20:48:19 nas ahcich21: <AHCI channel> at channel 21 on ahci0 Feb 16 20:48:19 nas ahcich22: <AHCI channel> at channel 22 on ahci0 Feb 16 20:48:19 nas ahcich23: <AHCI channel> at channel 23 on ahci0 Feb 16 20:48:19 nas ahcich24: <AHCI channel> at channel 24 on ahci0 Feb 16 20:48:19 nas ahcich25: <AHCI channel> at channel 25 on ahci0 Feb 16 20:48:19 nas ahcich26: <AHCI channel> at channel 26 on ahci0 Feb 16 20:48:19 nas ahcich27: <AHCI channel> at channel 27 on ahci0 Feb 16 20:48:19 nas ahcich28: <AHCI channel> at channel 28 on ahci0 Feb 16 20:48:19 nas ahcich29: <AHCI channel> at channel 29 on ahci0 Feb 16 20:48:19 nas pcib3: <ACPI PCI-PCI bridge> at device 21.0 on pci0 Feb 16 20:48:19 nas pci3: <ACPI PCI bus> on pcib3 Feb 16 20:48:19 nas mps0: <Avago Technologies (LSI) SAS2008> port 0x4000-0x40ff mem 0xfd4f0000-0xfd4fffff,0xfd480000-0xfd4bffff irq 18 at device 0.0 on pci3 Feb 16 20:48:19 nas mps0: Firmware: 20.00.07.00, Driver: 21.01.00.00-fbsd Feb 16 20:48:19 nas mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> Feb 16 20:48:19 nas pcib4: <ACPI PCI-PCI bridge> at device 21.1 on pci0 Feb 16 20:48:19 nas pci4: <ACPI PCI bus> on pcib4 Feb 16 20:48:19 nas pcib5: <ACPI PCI-PCI bridge> at device 21.2 on pci0 Feb 16 20:48:19 nas pci5: <ACPI PCI bus> on pcib5 Feb 16 20:48:19 nas pcib6: <ACPI PCI-PCI bridge> at device 21.3 on pci0 Feb 16 20:48:19 nas pci6: <ACPI PCI bus> on pcib6 Feb 16 20:48:19 nas pcib7: <ACPI PCI-PCI bridge> at device 21.4 on pci0 Feb 16 20:48:19 nas pci7: <ACPI PCI bus> on pcib7 Feb 16 20:48:19 nas pcib8: <ACPI PCI-PCI bridge> at device 21.5 on pci0 Feb 16 20:48:19 nas pci8: <ACPI PCI bus> on pcib8 Feb 16 20:48:19 nas pcib9: <ACPI PCI-PCI bridge> at device 21.6 on pci0 Feb 16 20:48:19 nas pci9: <ACPI PCI bus> on pcib9 Feb 16 20:48:19 nas pcib10: <ACPI PCI-PCI bridge> at device 21.7 on pci0 Feb 16 20:48:19 nas pci10: <ACPI PCI bus> on pcib10 Feb 16 20:48:19 nas pcib11: <ACPI PCI-PCI bridge> at device 22.0 on pci0 Feb 16 20:48:19 nas pci11: <ACPI PCI bus> on pcib11 Feb 16 20:48:19 nas pcib12: <ACPI PCI-PCI bridge> at device 22.1 on pci0 Feb 16 20:48:19 nas pci12: <ACPI PCI bus> on pcib12 Feb 16 20:48:19 nas pcib13: <ACPI PCI-PCI bridge> at device 22.2 on pci0 Feb 16 20:48:19 nas pci13: <ACPI PCI bus> on pcib13 Feb 16 20:48:19 nas pcib14: <ACPI PCI-PCI bridge> at device 22.3 on pci0 Feb 16 20:48:19 nas pci14: <ACPI PCI bus> on pcib14 Feb 16 20:48:19 nas pcib15: <ACPI PCI-PCI bridge> at device 22.4 on pci0 Feb 16 20:48:19 nas pci15: <ACPI PCI bus> on pcib15 Feb 16 20:48:19 nas pcib16: <ACPI PCI-PCI bridge> at device 22.5 on pci0 Feb 16 20:48:19 nas pci16: <ACPI PCI bus> on pcib16 Feb 16 20:48:19 nas pcib17: <ACPI PCI-PCI bridge> at device 22.6 on pci0 Feb 16 20:48:19 nas pci17: <ACPI PCI bus> on pcib17 Feb 16 20:48:19 nas pcib18: <ACPI PCI-PCI bridge> at device 22.7 on pci0 Feb 16 20:48:19 nas pci18: <ACPI PCI bus> on pcib18 Feb 16 20:48:19 nas pcib19: <ACPI PCI-PCI bridge> at device 23.0 on pci0 Feb 16 20:48:19 nas pci19: <ACPI PCI bus> on pcib19 Feb 16 20:48:19 nas pcib20: <ACPI PCI-PCI bridge> at device 23.1 on pci0 Feb 16 20:48:19 nas pci20: <ACPI PCI bus> on pcib20 Feb 16 20:48:19 nas pcib21: <ACPI PCI-PCI bridge> at device 23.2 on pci0 Feb 16 20:48:19 nas pci21: <ACPI PCI bus> on pcib21 Feb 16 20:48:19 nas pcib22: <ACPI PCI-PCI bridge> at device 23.3 on pci0 Feb 16 20:48:19 nas pci22: <ACPI PCI bus> on pcib22 Feb 16 20:48:19 nas pcib23: <ACPI PCI-PCI bridge> at device 23.4 on pci0 Feb 16 20:48:19 nas pci23: <ACPI PCI bus> on pcib23 Feb 16 20:48:19 nas pcib24: <ACPI PCI-PCI bridge> at device 23.5 on pci0 Feb 16 20:48:19 nas pci24: <ACPI PCI bus> on pcib24 Feb 16 20:48:19 nas pcib25: <ACPI PCI-PCI bridge> at device 23.6 on pci0 Feb 16 20:48:19 nas pci25: <ACPI PCI bus> on pcib25 Feb 16 20:48:19 nas pcib26: <ACPI PCI-PCI bridge> at device 23.7 on pci0 Feb 16 20:48:19 nas pci26: <ACPI PCI bus> on pcib26 Feb 16 20:48:19 nas pcib27: <ACPI PCI-PCI bridge> at device 24.0 on pci0 Feb 16 20:48:19 nas pci27: <ACPI PCI bus> on pcib27 Feb 16 20:48:19 nas pcib28: <ACPI PCI-PCI bridge> at device 24.1 on pci0 Feb 16 20:48:19 nas pci28: <ACPI PCI bus> on pcib28 Feb 16 20:48:19 nas pcib29: <ACPI PCI-PCI bridge> at device 24.2 on pci0 Feb 16 20:48:19 nas pci29: <ACPI PCI bus> on pcib29 Feb 16 20:48:19 nas pcib30: <ACPI PCI-PCI bridge> at device 24.3 on pci0 Feb 16 20:48:19 nas pci30: <ACPI PCI bus> on pcib30 Feb 16 20:48:19 nas pcib31: <ACPI PCI-PCI bridge> at device 24.4 on pci0 Feb 16 20:48:19 nas pci31: <ACPI PCI bus> on pcib31 Feb 16 20:48:19 nas pcib32: <ACPI PCI-PCI bridge> at device 24.5 on pci0 Feb 16 20:48:19 nas pci32: <ACPI PCI bus> on pcib32 Feb 16 20:48:19 nas pcib33: <ACPI PCI-PCI bridge> at device 24.6 on pci0 Feb 16 20:48:19 nas pci33: <ACPI PCI bus> on pcib33 Feb 16 20:48:19 nas pcib34: <ACPI PCI-PCI bridge> at device 24.7 on pci0 Feb 16 20:48:19 nas pci34: <ACPI PCI bus> on pcib34 Feb 16 20:48:19 nas acpi_acad0: <AC Adapter> on acpi0 Feb 16 20:48:19 nas atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 Feb 16 20:48:19 nas atkbd0: <AT Keyboard> irq 1 on atkbdc0 Feb 16 20:48:19 nas kbd0 at atkbd0 Feb 16 20:48:19 nas atkbd0: [GIANT-LOCKED] Feb 16 20:48:19 nas psm0: <PS/2 Mouse> irq 12 on atkbdc0 Feb 16 20:48:19 nas psm0: [GIANT-LOCKED] Feb 16 20:48:19 nas psm0: model IntelliMouse, device ID 3 Feb 16 20:48:19 nas orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xcafff,0xdc000-0xdffff,0xe0000-0xe7fff on isa0 Feb 16 20:48:19 nas sc0: <System console> at flags 0x100 on isa0 Feb 16 20:48:19 nas sc0: VGA <16 virtual consoles, flags=0x300> Feb 16 20:48:19 nas vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 Feb 16 20:48:19 nas coretemp0: <CPU On-Die Thermal Sensors> on cpu0 Feb 16 20:48:19 nas coretemp0: Tj(target) value 0 does not seem right. Feb 16 20:48:19 nas coretemp1: <CPU On-Die Thermal Sensors> on cpu1 Feb 16 20:48:19 nas coretemp1: Tj(target) value 0 does not seem right. Feb 16 20:48:19 nas ZFS filesystem version: 5 Feb 16 20:48:19 nas ZFS storage pool version: features support (5000) Feb 16 20:48:19 nas Timecounters tick every 1.000 msec Feb 16 20:48:19 nas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Feb 16 20:48:19 nas kernel: em0: link state changed to UP Feb 16 20:48:19 nas kernel: em0: link state changed to UP Feb 16 20:48:19 nas random: unblocking device. Feb 16 20:48:19 nas usbus0: 12Mbps Full Speed USB v1.0 Feb 16 20:48:19 nas usbus1: 480Mbps High Speed USB v2.0 Feb 16 20:48:19 nas ugen0.1: <0x15ad> at usbus0 Feb 16 20:48:19 nas uhub0: <0x15ad UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 Feb 16 20:48:19 nas ugen1.1: <0x15ad> at usbus1 Feb 16 20:48:19 nas uhub1: <0x15ad EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 Feb 16 20:48:19 nas uhub0: 2 ports with 2 removable, self powered Feb 16 20:48:19 nas ugen0.2: <VMware> at usbus0 Feb 16 20:48:19 nas ugen0.3: <vendor 0x0e0f> at usbus0 Feb 16 20:48:19 nas uhub2: <VMware Virtual USB Hub> on usbus0 Feb 16 20:48:19 nas uhub1: 6 ports with 6 removable, self powered Feb 16 20:48:19 nas mps0: SAS Address for SATA device = 816f9c51a7b6dbc7 Feb 16 20:48:19 nas mps0: SAS Address for SATA device = 816f9c51a7c8e1c7 Feb 16 20:48:19 nas mps0: SAS Address for SATA device = 3d533b1f84937e74 Feb 16 20:48:19 nas mps0: SAS Address for SATA device = 3d4c3b1f847c7e74 Feb 16 20:48:19 nas mps0: SAS Address for SATA device = 3d51491f86947376 Feb 16 20:48:19 nas mps0: SAS Address for SATA device = 3d4c4b1f8a775979 Feb 16 20:48:19 nas mps0: SAS Address from SATA device = 816f9c51a7b6dbc7 Feb 16 20:48:19 nas mps0: SAS Address from SATA device = 816f9c51a7c8e1c7 Feb 16 20:48:19 nas mps0: SAS Address from SATA device = 3d533b1f84937e74 Feb 16 20:48:19 nas mps0: SAS Address from SATA device = 3d4c3b1f847c7e74 Feb 16 20:48:19 nas mps0: SAS Address from SATA device = 3d51491f86947376 Feb 16 20:48:19 nas mps0: SAS Address from SATA device = 3d4c4b1f8a775979 Feb 16 20:48:19 nas uhub2: 7 ports with 7 removable, self powered Feb 16 20:48:19 nas ada0 at ahcich1 bus 0 scbus4 target 0 lun 0 Feb 16 20:48:19 nas ada0: <VMware Virtual SATA Hard Drive 00000001> ATA-6 SATA 2.x device Feb 16 20:48:19 nas ada0: Serial Number 01000000000000000001 Feb 16 20:48:19 nas ada0: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes) Feb 16 20:48:19 nas ada0: Command Queueing enabled Feb 16 20:48:19 nas ada0: 8192MB (16777216 512 byte sectors) Feb 16 20:48:19 nas ada0: Previously was known as ad6 Feb 16 20:48:19 nas da0 at mps0 bus 0 scbus33 target 0 lun 0 Feb 16 20:48:19 nas da0: <ATA TOSHIBA MG03ACA3 FL1A> Fixed Direct Access SPC-4 SCSI device Feb 16 20:48:19 nas da0: Serial Number 23M8K3LZF Feb 16 20:48:19 nas da0: 600.000MB/s transfers Feb 16 20:48:19 nas da0: Command Queueing enabled Feb 16 20:48:19 nas da0: 2861588MB (5860533168 512 byte sectors) Feb 16 20:48:19 nas da1 at mps0 bus 0 scbus33 target 1 lun 0 Feb 16 20:48:19 nas da1: <ATA TOSHIBA MG03ACA3 FL1A> Fixed Direct Access SPC-4 SCSI device Feb 16 20:48:19 nas da1: Serial Number 23F8K35ZF Feb 16 20:48:19 nas da1: 600.000MB/s transfers Feb 16 20:48:19 nas da1: Command Queueing enabled Feb 16 20:48:19 nas da1: 2861588MB (5860533168 512 byte sectors) Feb 16 20:48:19 nas da2 at mps0 bus 0 scbus33 target 2 lun 0 Feb 16 20:48:19 nas da2: <ATA TOSHIBA MG03ACA3 FL1A> Fixed Direct Access SPC-4 SCSI device Feb 16 20:48:19 nas da2: Serial Number 43KFK5MOF Feb 16 20:48:19 nas da2: 600.000MB/s transfers Feb 16 20:48:19 nas da2: Command Queueing enabled Feb 16 20:48:19 nas da2: 2861588MB (5860533168 512 byte sectors) Feb 16 20:48:19 nas da3 at mps0 bus 0 scbus33 target 3 lun 0 Feb 16 20:48:19 nas da3: <ATA TOSHIBA MG03ACA3 FL1A> Fixed Direct Access SPC-4 SCSI device Feb 16 20:48:19 nas da3: Serial Number 73FHK905F Feb 16 20:48:19 nas da3: 600.000MB/s transfers Feb 16 20:48:19 nas da3: Command Queueing enabled Feb 16 20:48:19 nas da3: 2861588MB (5860533168 512 byte sectors) Feb 16 20:48:19 nas da4 at mps0 bus 0 scbus33 target 4 lun 0 Feb 16 20:48:19 nas da4: <ATA Hitachi HDS72202 A28A> Fixed Direct Access SPC-4 SCSI device Feb 16 20:48:19 nas da4: Serial Number JK1175YAHSV60X Feb 16 20:48:19 nas da4: 300.000MB/s transfers Feb 16 20:48:19 nas da4: Command Queueing enabled Feb 16 20:48:19 nas da4: 1907729MB (3907029168 512 byte sectors) Feb 16 20:48:19 nas da5 at mps0 bus 0 scbus33 target 5 lun 0 Feb 16 20:48:19 nas da5: <ATA Hitachi HDS72202 A28A> Fixed Direct Access SPC-4 SCSI device Feb 16 20:48:19 nas da5: Serial Number JK1175YAHSVH6X Feb 16 20:48:19 nas da5: 300.000MB/s transfers Feb 16 20:48:19 nas da5: Command Queueing enabled Feb 16 20:48:19 nas da5: 1907729MB (3907029168 512 byte sectors) Feb 16 20:48:19 nas SMP: AP CPU #1 Launched! Feb 16 20:48:19 nas Trying to mount root from zfs:freenas-boot/ROOT/default []... Feb 16 20:48:19 nas GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) Feb 16 20:48:19 nas hwpc_core: unknown PMC architecture: 1 Feb 16 20:48:19 nas hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> Feb 16 20:48:19 nas VMware memory control driver initialized Feb 16 20:48:19 nas uhid0: <VMware> on usbus0 Feb 16 20:48:19 nas uhid1: <VMware> on usbus0 Feb 16 20:48:19 nas root: /etc/rc: WARNING: failed to start watchdogd Feb 16 20:48:19 nas GEOM_ELI: Device da0p1.eli created. Feb 16 20:48:19 nas GEOM_ELI: Encryption: AES-XTS 128 Feb 16 20:48:19 nas GEOM_ELI: Crypto: hardware Feb 16 20:48:19 nas GEOM_ELI: Device da1p1.eli created. Feb 16 20:48:19 nas GEOM_ELI: Encryption: AES-XTS 128 Feb 16 20:48:19 nas GEOM_ELI: Crypto: hardware Feb 16 20:48:19 nas GEOM_ELI: Device da2p1.eli created. Feb 16 20:48:19 nas GEOM_ELI: Encryption: AES-XTS 128 Feb 16 20:48:19 nas GEOM_ELI: Crypto: hardware Feb 16 20:48:19 nas GEOM_ELI: Device da3p1.eli created. Feb 16 20:48:19 nas GEOM_ELI: Encryption: AES-XTS 128 Feb 16 20:48:19 nas GEOM_ELI: Crypto: hardware Feb 16 20:48:19 nas GEOM_ELI: Device da4p1.eli created. Feb 16 20:48:19 nas GEOM_ELI: Encryption: AES-XTS 128 Feb 16 20:48:19 nas GEOM_ELI: Crypto: hardware Feb 16 20:48:19 nas GEOM_ELI: Device da5p1.eli created. Feb 16 20:48:19 nas GEOM_ELI: Encryption: AES-XTS 128 Feb 16 20:48:19 nas GEOM_ELI: Crypto: hardware Feb 16 20:48:20 nas ntpd[1850]: ntpd 4.2.8p9-a (1): Starting Feb 16 20:48:22 nas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Feb 16 20:48:20 nas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Feb 16 20:48:21 nas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Feb 16 20:48:22 nas smbd: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:35 Err:-1 Errno:2 No such file or directory Feb 16 20:54:36 nas ntpd[1851]: frequency error 3713 PPM exceeds tolerance 500 PPM
