DNS/Plugin install problems after upgrading from 11.1 U7 to 11.3 U2
Bjureus1
Yesterday I installed Freenas 11.3 U2 and got major problems with network and plugins who didnt install du to DNS problems.
Today I did a fresh install of Freenas 11.1 U7 because this was the last stable version before trying the later versions.
I also did a upgrade from 11.1 to 11.3 from GUI tonight, with the same result = SHIT!
I also got some diffrent errors switching from dhcp and nat when trying to install plugins.
I also got an error about not knowing default NIC, i have 2 igb0 and igb1
It doesnt make any differens if I go for static och dhcp on the server either.
Seems like Im not able to run 11.3 U2 on my sytstem
Can someone please be so kind and help out, this is getting very frustrating!
SYSTEM:
Global net config:
IPv4: 192.168.0.200
Default gateway: 192.168.0.1
Name server 1: 84.208.20.110
Name server 2: 84.208.20.111
Igb0: UP
Igb1: DOWN
  • Motherboard make and model:
    Asrock rack c2550d4i
  • CPU make and model:
    Intel Avoton C2550 Quad-Core Processor
  • RAM quantity:
    8Gb
  • Hard drives, quantity, model numbers, and RAID configuration, including boot drives
    HDD 3 x WDC WD30EFRX-68EUZN0 (RAIDMIRROR)
    SSD 1 xKINGSTON SA400S37120G
  • Hard disk controllers:
    Intel® C2550 : 2 x SATA3 6.0 Gb/s, 4 x SATA2 3.0 Gb/s
    Marvell SE9230: 4 x SATA3 6.0 Gb/s, support RAID 0, 1, 10
    Marvell SE9172: 2 x SATA3 6.0 Gb/s, support RAID 0, 1
  • Network cards:
    Gigabit LAN 10/100/1000 Mb/s
    2 x Intel® i210 controller
Redcoat
I used to have the similar c2750d4i - let's see if my experience with it "translates".
First off, I assume that you have only one network cable plugged in to the ports on the back of the board, and the port you are using in one of the two that are paired vertically, nit the one that is above the two usb ports.
Then I would change nameserver 1 to your gateway address and move the name servers you have (that I saw you report finding in your posts last week) to 2 and 3.
I take it that you have igb0 set for static 192.168.0.200/24 - yes?
Bjureus1
Yes I’m using one of the 2, not the IPMI port.
Yes igb0 is set to static.
tried changing name server 1 to 192.68.0.1 without luck unfortunately.
get the same error when trying to install a plugin:
failure Exception: RuntimeError Message: No default interface found Partial plugin destroyed
Redcoat
Can you ping out from the shell to say google.com? 8.8.4.4?
you say you see that same error when installing a plug in.
When else do you see it?
Redcoat
Also, please post the output of ifconfig in code tags.
Redcoat
When you installed FreeNAS did you choose UEFI or legacy boot? If UEFI, try an install in Legacy mode, please.
Bjureus1
Error is diffrent if I choose NAT or DHCP, either I get "DNS problems" or "no default interface"
Yes I can ping both google.com and 8.8.4.4 with default gateway as 192.168.0.1 and name server 1 & 2
I dont know if I installed in legacy or UEFI, just went to the update tab and choosed 11.3 U2 and hit install.
Where can I choose between legacy and UEFI?
root@freenas:~ # ifconfig
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: Link1
        options=6002bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO6,RXCSUM_IPV6,TXCSUM_IPV6>
        ether d0:50:99:1b:65:11
        hwaddr d0:50:99:1b:65:11
        inet 192.168.0.200 netmask 0xffffff00 broadcast 192.168.0.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
        ether d0:50:99:1b:65:12
        hwaddr d0:50:99:1b:65:12
        nd6 options=1<PERFORMNUD>
        status: no carrier
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        groups: lo
        ether 02:42:7a:8a:a2:00
Redcoat
Please post a screenshot of the Network/interfaces/Edit page for igb0 - like this one
To Legacy boot you would have to choose at install when creating a new boot drive.
But this is an upgrade from a previous version that did not have problems?
Bjureus1
Yes this was a upgrade from 11.1 U7 that worked with these settings.
Redcoat
OK, so far all this looks logical.
Is your router set up to act as a DHCP server?
What plugin(s) are you trying to install?
Bjureus1
Router is set up to act DHCP sever with pool from 10 to 140
Transmission and emby
Maybe have to install 11.1 once more and then make a flashdrive with 11.3 and legacy install it
Redcoat
DHCP server sounds OK.
I don't use plugins and thus know nothing about them. I only use jails. Not much more I can help with here I don't think.
Have you thought about trying to install one or both in a jail (much preferable IMO)?
Bjureus1
Installing thru plugins install them in a jail?
Not so familiar with Linux or FreeNAS but if you can explain how to I guess I could try.
still think this error is weird, think I had 11.2 as well with no network problems.
Redcoat
Yes, error is weird...
Go to Resources section for https://www.ixsystems.com/community...darr-lidarr-jackett-transmission-organizr.58/
For emby and others, see https://www.ixsystems.com/community...sabnzbd-emby-working-in-an-iocage-jail.75812/ less details here but once you've made a j jail, use pkg install. Look at Fresh Ports to find out the name of the pkg - looks like pkg install emby-server https://www.freshports.org/multimedia/emby-server/
I would keep down loader transmission in a separate jail from media player emby, personally, but that's just me.
You'll find these jails are easier to maintain than plug-ins - keep the data store separate on your main pool than you can update the pkg in the jail anytime without screwing up the app.
Bjureus1
Thx
FYI
I now tried everyting, upgrading from GUI, Flashdisk etc.
Nothing works properly, neither 11.2 U8 or 11.3 U2
Only thing that works is 11.1 U7
