Garyw
- Sep 4, 2011
I've got a really weird on here that I'm at a loss to explain.
Work have a freeNAS box that works perfectly most of the time but for some reason (and I suspect someone changed something but no one is owning up), the DNS settings are inconsistent.
If I go to the DNS settings in the GUI, I can see the internal DNS servers - that's all good.
If I go to the console and look at resolv.conf it shows:
# Generated by resolvconf
nameserver 127.0.01
If I change the DNS servers in the GUI it doesn't update the resolv.conf
If I change them via 6) Configure DNS at the console it doesn't update the resolv.conf
I have noticed that I get a 'call timeout' on that page though.
Name resolution is not working so AD Integration is broken.
This is FreeNAS-11.2-U5
Suggests appreciated!
Thanks.
nameserver 127.0.01
Thanks.
