A bit of an odd one here. This is from a fresh install of TrueNAS-SCALE-22.02.0.1 on an HP Microserver Gen8. It was running TrueNAS core (current version) until the USB boot drive bit the dust so I did a clean install, reimported the pool and am configuring the various shares.
The original symptoms were from a generic error unable to download the package catalog. Digging a little further on the command line I'm getting the following very specific error:
but resolv.conf looks fine (autogenerated via DHCP with a reserved IP)
When I manually override the DHCP supplied configuration in the UI, the format of resolv.conf changes to each DNS server on a separate line and this seems to work:
host github.com host: parse of /etc/resolv.conf failed
cat /etc/resolv.conf domain infrageeks.lan nameserver 192.168.2.240,192.168.10.199,192.168.5.199
cat /etc/resolv.conf domain infrageeks.lan nameserver 192.168.2.240 nameserver 192.168.10.199 nameserver 192.168.5.199
