I've experienced this problem before multiple times with FreeNAS, but cannot find the solution this time.
New build, no DNS ... so updates fail
Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: Automatic update check failed. Please check system network settings.
I can ping IP addresses (172.217.14.206), but can't ping google.com
ping: cannot resolve google.com: Host name lookup failure
Network summary states
Default routes 192.168.0.1 (correct)
Name servers 192.168.0.5 (correct) 127.0.0.1
Fields within the Global Configuration (network) are blank, yet making any changes does not resolve the problem
My /etc/resolv.conf is the following (created by DHCP)
#Generated by resolvconf
search local localdomain
nameserver 127.0.0.1
and of course that is a problem, and manually entering a correct nameserver to this file immediately fixes the problem, but a reboot resets the resolv.conf file back to how it was
it is probably an easy fix, but I can't find my solution and I've dealt with this multiple times before.
Thanking you in advance!
