Daisuke
- Jun 23, 2011
I have this setup. When I did a check:
% diskinfo -t /dev/sda0
the sectorsize is set to 512 instead of 4096? I run 6 WD20EARS disks set on ZFS Raidz1.
I thought this issue was addressed in 8.0.1, so we don't need to use jumpers on disks. I did not forced the 4K sector when I created the volumes because I was sure this is solved...
Thanks for your help.
