disk pool throwing alert
georgelza
I"ve noticed that I executed the below, without giving it a name, as such, how do I attach to it ?
tmux list-sessions
/usr/sbin/zfs send -R tank/media@media | zfs recv -Fv bunker/media: 1 windows (created Mon Aug 7 20:38:06 2023)
G
If there's only one session running, you can just tmux attach
If there are many, you indeed need to know the name (or ID) of the session (I think you can see that as "1" in the list above).
If that is still running, I wouldn't be messing with rsync on the same structure.
georgelza
had a curious problem during the night.
so we have Tank\media, it was using (6TB) 90% on tank of 7.1...
so we had bunker that had bunker\TimeMachine/2Tib and bunker\home that was 485GB on 7.1
we now resized bunker to 14Tib. My math told me had enough space for tank\media
we resync'd... tank\media to bunker\media which seems to end incomplete, so we did a rsync, update missing, which now suddenly occupying 12Tib, filling bunker 100%.
I repointed my shares back to tank\ ... going to delete bunker\media and then ???
G
georgelza
think I can probably improve on this badblock check... speed...
it's just under 24hours and still busy, and zero errors on this drive so far, this is also not one of the drives that previously threw errors.
command used:
tmux new-session -d -s badblocks '/usr/sbin/badblocks -c 1024 -e 64 -p 1 -svw -o /root/badblocks/sda.out /dev/sda'
G
No, you probably can't.
Blocks are written to the disk at the speed they can be written. As mentioned already in the thread, optimization can be done to match block sizes, but that's it (and you already did it... unless you selected the wrong number for those drives).
I'd be looking at why that failed first rather than just trying to fix it with rsync.
Are you doing recursive zfs send? maybe the child datasets are what's missing.
georgelza
The original command executed was... - this completed, but then we said lets check and we found missing files, this was then followed by the 2nd command.
1st: tmux new-session -d -s zfscopy '/usr/sbin/zfs send -R tank/media@media | zfs recv -Fv bunker/media'
remember the 1st command was done with no "media" dataset defined on "bunker"
the command created "media"
2nd: tmux new-session -d -s rsync 'rsync -auv /mnt/tank/media /mnt/bunker/media'
for now my idea is to delete "media" from "bunker" and then restart... as "media" has now filled up "bunker" as it's occupying 12Tib atm.
G
georgelza
I don't
Was that snapshot recursive?
know, don't know ifs copy, that was the command I executed as per your suggestion.
the snapshot was created via:
/usr/sbin/zfs snapshot -r tank/media@media
and then the original copy was done as:
G
the -r is "recursive", so it's fine.
I would change that this time so you can see progress:
tmux new-session -d -s zfscopy '/usr/sbin/zfs send -R tank/media@media | pv | zfs recv -Fv bunker/media'
georgelza
ok. deleting current dataset from bunker and recreating using above command.
thanks
G
georgelza
I've delete the media dataset from "bunker" but there still seems to be space occupied ?
G
Check for snapshots:
zfs list -t snap | grep bunker
georgelza
there are allot, but they all related to a dataset thats always been there.
but might be idea to clean them up anyhow...
G
georgelza
ok, bunker cleaned up, back to 2Tib use out of the avail 14.4
zfs snapshot recreated.
In Progress:
G
georgelza
zfscopy finished, we going to do a compare again ?
G
georgelza
immediately after the above copy finished... (after below command completed)
< tmux new-session -d -s zfscopy '/usr/sbin/zfs send -R tank/media@media | pv | zfs recv -Fv bunker/media' >
I executed : < tmux new-session -d -s rsync 'rsync -auv /mnt/tank/media /mnt/bunker/media' >
resulting in...
sending incremental file list
media/
media/G-movies/
media/G-movies/.DS_Store
media/G-movies/DaveShaw/
media/G-movies/DaveShaw/Dave Not Coming Back (1080p) - Documentary, Adventure, Heroes.mp4
media/G-movies/Halo/
media/G-movies/Halo/.DS_Store
media/G-movies/Halo/HALO Full Movie (2021) 4K ULTRA HD Action All Cinematics Full Story.webm
resulting in...
media/
media/G-movies/
So did those 2 files arrive after the snapshot was taken?
In that case, makes perfect sense.
georgelza
not understanding, which 2 files ?
As I understood, we took a snap shot, we then told ZFS to write the snapshot (which was a full snapshot of /tank/media) to /bunker/media (this creating the media dataset on bunker diskpool),
We now doing a compare, I would expect a zero delta... instead what I'm understanding that list of files showing on the output is files it is saying it needs to write.
maybe a different question, how else can I move tank/media to bunker so that I end with bunker/media as a clone/copy.
G
Those 2 files.
Was that the full list from the rsync output?
If only those 2 files are different, perhaps there's some kind of problem with them... I'm just assuming that they may be added while the zfs send was in progress (or any time after the snapshot was taken).
