Disk not showing pool after being added
ITGuy1024
Hey all,
I have a pool with 2 mirrored drives that I use for some VMs. I started the process of replacing the drives with larger ones. The first drive has been removed, the new one added and the resilver appears to have completed successfully. From what I can tell the pool appears healthy.
However under Disks the newly added drive just shows N/A for the pool association.
Is this maybe a GUI bug?
Patrick M. Hausen
How did you perform the replacement?
ITGuy1024
I followed this
Alecmascot
As I recall there was a fix for this in later releases.
It is only cosmetic.
Patrick M. Hausen
@ITGuy1024 So you used the UI? This problem can show up when one does a replacement via command line and uses e.g. /dev/adaX instead of creating a proper partition table. If that can be ruled out, you should probably update to the latest patch release.
ITGuy1024
da4 is the new drive
ITGuy1024
After applying a few pending updates and the server rebooting the Pool shows up on the drive now. Thanks!
