I hope I'm allowed to make this post but I just woke up today to 9 truenas emails saying
Will I need to replace the drive? It is kinda old but still unfortunate. I'm not sure what the best next step is. This is what smartctl says even though it is from when I tested it before it happened? https://pastebin.com/DaHdkGZ4. Should I do another smart test? Scrub? Right now I'm coping all the data onto a removable hard drive from my other drive in the mirror just in case. The faulted drive is not being used from what I can tell.
Thank you
Device: /dev/sdb [SAT], 1360 Offline uncorrectable sectors. andCode:
Pool Storage state is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
The following devices are not healthy:
Disk ST3000DM001-1ER166 Z502GAMY is FAULTEDWill I need to replace the drive? It is kinda old but still unfortunate. I'm not sure what the best next step is. This is what smartctl says even though it is from when I tested it before it happened? https://pastebin.com/DaHdkGZ4. Should I do another smart test? Scrub? Right now I'm coping all the data onto a removable hard drive from my other drive in the mirror just in case. The faulted drive is not being used from what I can tell.
Thank you
