- Jul 3, 2015
This isn't new and Im sure like me lots of you have already been using this utility for years but thought it might be worth a mention as it does seem to crop up from time-to-time.
If you happen to be using a Broadcom/LSI/Avago HBA card in your setup then you may want to make use of the sas2ircu or sas3ircu utility (depending on your card) which can aid in identifying drives in their physical slots.
There are a few different ways you can use the utility but I thought I'd share how I use it.
If I need to identify a failed or failing drive then I will often know the corresponding da number so in that case I can run
Then I can then run
Now this alone may not be that helpful but now we have that info we can turn the light on by using this cmd
You can also simply run
Like I said Im sure this is bread and butter to some of you but it may be helpful to others that were not aware of this.
smartctl -a /dev/da0 to get the serial number of that drive.Then I can then run
sas3ircu 0 display | grep serialnumber -A2 -B8 and that will return to me the drives physical location in the chassis. Locations are identified by their expander and then slot so for example on my system da0 (as it is now) happens to sit in 2:0.Now this alone may not be that helpful but now we have that info we can turn the light on by using this cmd
sas3icru 0 locate 2:0 ON and a light will appear on that slot. The cmd sas3ircu 0 locate 2:0 OFF will turn the light off when you are finished.You can also simply run
sas3ircu 0 display to get a full list of all your connected drives and their location within the system along with some other info.sas3ircu list will list all Broadcom/LSI/Avago HBAs in your system.Like I said Im sure this is bread and butter to some of you but it may be helpful to others that were not aware of this.
