I am new to TrueNAS and have been using it for almost 1 year. I recently felt my server (hard drive) is making strange noise and I got the following alerts when I logged in.
I did some research online and performed the SMART short test and long/extended test. Here is the result after the test has finished.
I also got another alert once the test finished.
In my setup, there are 2 Seagate EXOS 18TB drives running in mirror mode. The hardware is an old Dell workstation (Precision E1650) running VMware EXSi 7 with HBA passthrough. The server is running almost continuously over the past 9 months (I turn it off for maintenance occasionally). It is also plugged into an UPS, so there is not many hard shutdown.
Other than the Critical alerts, I don't think there are any data errors reported by ZFS so far. But the unusual noise of the machine makes me kinda uncomfortable (it sounds like the disk is keep seeking or performing large amount of random IO, but I am sure it doesn't as our workload hasn't changed, and the machine sounds normal during the SMART long test). What should I do next? Should I replace the disk? Thanks
CRITICAL Device: /dev/ada1, 13 Currently unreadable (pending) sectors. CRITICAL Device: /dev/ada1, 13 Offline uncorrectable sectors.
root@truenas[~]# smartctl -a /dev/ada1
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Device Model: ST18000NM000J-2TV103
Serial Number: ZRXXXXXX
LU WWN Device Id: 5 000c50 0e34b9bc2
Firmware Version: SN01
User Capacity: 18,000,207,937,536 bytes [18.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Jul 12 20:08:24 2023 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 116) The previous self-test completed having
the read element of the test failed.
data collection: ( 559) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1543) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 084 064 044 Pre-fail Always - 231541083
3 Spin_Up_Time 0x0003 090 090 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 85
5 Reallocated_Sector_Ct 0x0033 076 076 010 Pre-fail Always - 4020
7 Seek_Error_Rate 0x000f 077 060 045 Pre-fail Always - 50217697
9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6621
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 80
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 087 087 000 Old_age Always - 13
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 047 043 000 Old_age Always - 53 (Min/Max 38/57)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 55
193 Load_Cycle_Count 0x0032 084 084 000 Old_age Always - 32679
194 Temperature_Celsius 0x0022 053 057 000 Old_age Always - 53 (0 17 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 13
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 13
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 3984 (6 247 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 10404755145
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 45079713739
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed: read failure 40% 6617 -
# 2 Short offline Completed without error 00% 6601 -
1 0 0 Not_testing
2 0 0 Not_testingI also got another alert once the test finished.
CRITICAL Device: /dev/ada1, Self-Test Log error count increased from 0 to 1.
