[root@freenas] ~# zpool status
pool: BigDisk
state: ONLINE
status: The pool is formatted using a legacy on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on software that does not support feature
flags.
scan: scrub in progress since Fri Sep 13 13:08:04 2013
18.3G scanned out of 415G at 112M/s, 1h0m to go
0 repaired, 4.41% done
NAME STATE READ WRITE CKSUM
BigDisk ONLINE 0 0 0
gptid/9d779ca0-f208-11e2-b905-0015179cb91a ONLINE 0 0 0
output of smartctl -a /dev/da5 (that being this disk) (note that i'm doing a scrub while taking these commands)
SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 59761504 3 Spin_Up_Time 0x0003 074 074 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 62 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 067 060 030 Pre-fail Always - 6288827 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1293 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 52 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 098 000 Old_age Always - 4 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 073 054 045 Old_age Always - 27 (Min/Max 26/32) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 39 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 75 194 Temperature_Celsius 0x0022 027 046 000 Old_age Always - 27 (0 14 0 0 0) 195 Hardware_ECC_Recovered 0x001a 037 006 000 Old_age Always - 59761504 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 394 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 252831839814931 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1586137656 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3149995878
after i copy pasted this in here i ran the command again
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 79403472 3 Spin_Up_Time 0x0003 074 074 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 62 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 067 060 030 Pre-fail Always - 6289143 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1293 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 52 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 098 000 Old_age Always - 4 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 073 054 045 Old_age Always - 27 (Min/Max 26/32) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 39 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 75 194 Temperature_Celsius 0x0022 027 046 000 Old_age Always - 27 (0 14 0 0 0) 195 Hardware_ECC_Recovered 0x001a 036 006 000 Old_age Always - 79403472 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 394 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 14392435410195 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1586144127 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3198656130
so should i be worried that the disk is dieing or not?
zpool status gives me no errors but the read errors seems to increase exponentially...
