thimplicity
- Jan 6, 2022
Hi everyone,
I am running TrueNAS virtualized on Proxmox and yesterday morning I was greeted with the error message:
I have ran smartctl long overnight and this is the result:
I am also running scrutiny in my homelab and this is the "export".
Few questions on next steps:
Pool data-pool state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk ATA ST4000VN008-2DR1 ZM417ZGZ is FAULTED
root@truenas[~]# smartctl -a /dev/da2
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family: Seagate IronWolf
Device Model: ST4000VN008-2DR166
Serial Number: ZM417ZGZ
LU WWN Device Id: 5 000c50 0c647b36d
Firmware Version: SC60
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5980 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Oct 19 06:54:39 2023 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 113) The previous self-test completed having
the read element of the test failed.
data collection: ( 581) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 636) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 064 064 044 Pre-fail Always - 169631716
3 Spin_Up_Time 0x0003 094 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 59
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 095 060 045 Pre-fail Always - 3038528488
9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 27370 (49 4 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 57
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 068 068 000 Old_age Always - 32
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 65537
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 062 051 040 Old_age Always - 38 (Min/Max 36/47)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 64
193 Load_Cycle_Count 0x0032 030 030 000 Old_age Always - 141062
194 Temperature_Celsius 0x0022 038 049 000 Old_age Always - 38 (0 18 0 0 0)
197 Current_Pending_Sector 0x0012 100 099 000 Old_age Always - 72
198 Offline_Uncorrectable 0x0010 100 099 000 Old_age Offline - 72
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 26492h+49m+33.779s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 142200168728
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 95282192711
SMART Error Log Version: 1
ATA Error Count: 32 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 32 occurred at disk power-on lifetime: 27348 hours (1139 days + 12 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 00 00 ff ff ff 4f 00 4d+19:29:01.942 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 4d+19:29:01.941 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 4d+19:29:01.940 WRITE FPDMA QUEUED
61 00 10 ff ff ff 4f 00 4d+19:29:01.939 WRITE FPDMA QUEUED
Error 31 occurred at disk power-on lifetime: 27348 hours (1139 days + 12 hours)
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
60 00 00 ff ff ff 4f 00 4d+19:28:57.796 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:57.791 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:57.788 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:57.785 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:57.768 READ FPDMA QUEUED
Error 30 occurred at disk power-on lifetime: 27348 hours (1139 days + 12 hours)
61 00 00 ff ff ff 4f 00 4d+19:28:57.308 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 4d+19:28:53.841 WRITE FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:53.840 READ FPDMA QUEUED
Error 29 occurred at disk power-on lifetime: 27348 hours (1139 days + 12 hours)
60 00 00 ff ff ff 4f 00 4d+19:28:53.826 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:50.186 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:50.182 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:50.130 READ FPDMA QUEUED
61 00 00 ff ff ff 4f 00 4d+19:28:49.863 WRITE FPDMA QUEUED
Error 28 occurred at disk power-on lifetime: 27348 hours (1139 days + 12 hours)
60 00 00 ff ff ff 4f 00 4d+19:28:49.791 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:46.178 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:46.166 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 4d+19:28:46.162 READ FPDMA QUEUED
# 1 Extended offline Completed: read failure 10% 27365 -
# 2 Short offline Completed without error 00% 27359 -
# 3 Extended offline Completed without error 00% 27279 -
# 4 Short offline Completed without error 00% 27221 -
# 5 Short offline Completed without error 00% 27053 -
# 6 Short offline Completed without error 00% 26885 -
# 7 Short offline Completed without error 00% 26717 -
# 8 Extended offline Completed without error 00% 26558 -
# 9 Short offline Completed without error 00% 26549 -
#10 Short offline Completed without error 00% 26381 -
#11 Short offline Completed without error 00% 26213 -
#12 Short offline Completed without error 00% 26045 -
#13 Short offline Completed without error 00% 25878 -
#14 Extended offline Completed without error 00% 25819 -
#15 Short offline Completed without error 00% 25717 -
#16 Short offline Completed without error 00% 25549 -
#17 Short offline Completed without error 00% 25381 -
#18 Short offline Completed without error 00% 25212 -
#19 Extended offline Completed without error 00% 25081 -
#20 Short offline Completed without error 00% 25044 -
#21 Short offline Completed without error 00% 24877 -
1 0 0 Not_testing
2 0 0 Not_testingI am also running scrutiny in my homelab and this is the "export".
- Based on what I read in the forum, I assume the drive is done. Is that a correct assumption?
- I am running this drive in a mirror with an identical drive. Can I still use the other drive to save data?
- This drive is a 4TB drive. Can I combine a 3TB with it in a mirror? I am currently using 900GB of that mirror, but all the data is on the 4TB drive.
