Sir.Robin
- Apr 14, 2012
Look!!:
:D
Model Family: Seagate Barracuda ES
Device Model: ST3750640NS
Serial Number: 3QD0QV0Z
LU WWN Device Id: 5 000c50 0026092b0
Firmware Version: 3.BKE
User Capacity: 750,156,374,016 bytes [750 GB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Tue May 26 12:41:54 2015 CEST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 430) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 221) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 100 087 006 Pre-fail Always - 49167025
3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 90
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 082 060 030 Pre-fail Always - 199294583
9 Power_On_Hours 0x0032 032 032 000 Old_age Always - 60000
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 101
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 056 040 045 Old_age Always In_the_past 44 (Min/Max 38/48 #206)
194 Temperature_Celsius 0x0022 044 060 000 Old_age Always - 44 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 049 048 000 Old_age Always - 199247683
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0
202 Data_Address_Mark_Errs 0x0032 100 253 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged:D
