hugovsky
- Dec 12, 2011
Hello everyone. There used to be a thread like this a few years ago. This thread is to be used to post your disks age.
10 and a half years running freenas 9.2.1.8
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p12 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Hitachi Deskstar 5K3000
Device Model: Hitachi HDS5C3020ALA632
Serial Number: ML4220F3150PRK
LU WWN Device Id: 5 000cca 369d05ffd
Firmware Version: ML6OA580
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5940 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Jun 3 16:06:55 2022 WEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (23985) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 400) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 103
3 Spin_Up_Time 0x0007 160 160 024 Pre-fail Always - 407 (Average 277)
4 Start_Stop_Count 0x0012 098 098 000 Old_age Always - 11875
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 146 146 020 Pre-fail Offline - 29
9 Power_On_Hours 0x0012 087 087 000 Old_age Always - 91977
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1167
192 Power-Off_Retract_Count 0x0032 091 091 000 Old_age Always - 11923
193 Load_Cycle_Count 0x0012 091 091 000 Old_age Always - 11923
194 Temperature_Celsius 0x0002 187 187 000 Old_age Always - 32 (Min/Max 16/42)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 18787 -
# 2 Short offline Completed without error 00% 18763 -
# 3 Extended offline Completed without error 00% 18744 -
# 4 Short offline Completed without error 00% 18715 -
# 5 Short offline Completed without error 00% 18691 -
# 6 Short offline Completed without error 00% 18667 -
# 7 Short offline Completed without error 00% 18643 -
# 8 Short offline Completed without error 00% 18619 -
# 9 Short offline Completed without error 00% 18595 -
#10 Short offline Completed without error 00% 18571 -
#11 Short offline Completed without error 00% 18547 -
#12 Short offline Completed without error 00% 18523 -
#13 Short offline Completed without error 00% 18499 -
#14 Short offline Completed without error 00% 18475 -
#15 Short offline Completed without error 00% 18451 -
#16 Short offline Completed without error 00% 18427 -
#17 Extended offline Completed without error 00% 18408 -
#18 Short offline Completed without error 00% 18379 -
#19 Short offline Completed without error 00% 18355 -
#20 Short offline Completed without error 00% 18331 -
#21 Short offline Completed without error 00% 18307 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
