Greetings everyone
I'm trying, for the first time, the nextcloud plugin. After installing, I have noticed nextcloud navigation unusual slow. For example: closing a card, on Deck's tool, takes 15 seconds or more. Loading any page also too slow, although truenas shares seems to work just fine(I dont have VMs). After some research, I came to conclusion I must to try disabling hardware offloading, but every time I go to "Interface Settings", to check if "disable hardware offloading" is indeed marked, this popup keeps showing up https://prnt.sc/3LUXa5P0cxph
I repeat steps to disable again and again, but that popup always shows up. No performance improvements on plugin, though. Any ideas?
Version:
TrueNAS-12.0-U8
Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
16 GB DDR 3
Motherboard: Gigabyte H61M-S1
NIC: Realtek RTL8111F LAN chip (10/100/1000 Mbit)
Version:
TrueNAS-12.0-U8
16 GB DDR 3
