fukie
 - Feb 12, 2014
I have been doing some research as I am interested on connecting two FreeNAS boxes directly, without a switch for dedicated syncing. The objective of this idea is:
FreeNAS 01 <----------> FreeNAS 02
Switch 01 Switch 01
- Switch 01 to users
The idea can be expanded to directly connect FreeNAS 01 to servers / workstations with high bandwidth, providing a dedicated high speed pipe for faster transfers.
Syncing would be done either via rsync or ZFS replication. I am still researching which is more suitable but most likely I will go for rsync via a script, as I have planned for the backup box to automatically shut down after the sync is completed. And if possible to wake up automatically (using WOL) to perform the syncing.
Based on what I researched so far, the above setup is possible:
Thanks!`
- Reduce network load
 - Improve performance of syncing
 - Use multiple 1 GbE links with LACP (not sure yet if this is possible without a LACP switch) OR
 - Migrate to 10 GbE links first before moving to a 10 GbE switch
Switch 01 Switch 01
- With minimal/no 'hacking' required
 - Network configuration is all required for the direct link to work
 - Network configurations of the direct link and switch link should reside on different subjects to avoid conflicts
 - Network configuration of direct link would not have a gateway.
Thanks!`
