zpool status boot-pool and gpart show and I can guide you.Their system just might not boot now.What's the problem you bumped into? Is there a problem?
Reinstall. And sorry - just noticed this is SCALE. Forget my first post. I could only help you with CORE. If the system was still running, that is.It doesn't boot. It just goes to the Grub menu.
The boot loader must support the ZFS features. If it doesn't - no boot.
Can someone on SCALE confirm that it indeed does notify the user they can upgrade their boot-pool? (That should outright be removed. Otherwise, you're setting up users to hijack themselves with an unbootable system.)If this is an issue of Grub, why would SCALE even notify the user that their boot-pool can be upgraded? That seems like a bad design.
No, it doesn't. But that doesn't prevent people from doingCan someone on SCALE confirm that it indeed does notify the user they can upgrade their boot-pool?
No need, as there is no such option.(I would go even further and remove the "upgrade" option from the GUI for the boot-pool.)
In my experience, this last sentence pretty much sums up the experience of having GRUB as bootloader.Otherwise, you're setting up users to hijack themselves with an unbootable system.)
root@truenas[~]# zpool status
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:13 with 0 errors on Sun Oct 15 03:45:14 2023
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
sda3 ONLINE 0 0 0
errors: No known data errors
