SOLVED Detached drive causes system log to fill and system to become unresponsive
NASbox
I upgraded from 11.1-U7 to 11.2-U7 and my log started to fill with these messages:
Dec 7 14:15:44 freenas ZFS: vdev state changed, pool_guid=1487853121776782679 vdev_guid=12501387109407037534
and the system became unresponsive and had to be power cycled.
How do identify what pool/drive pool_guid=1487853121776782679 vdev_guid=12501387109407037534 relate to?
(converting the numbers (which appears to be decimal) to hex didn't yield anything obvious.)
What state changed?
When I reverted to 11.1-U7, the problem disappeared. Any suggestions?
G8One2
I get those when a scrub is initiated on the pool. They arent really errors rather, informational. The system becoming unresponsive is likely, a different issue.
NASbox
In my case I am getting several hundred of them -- the system becomes totally unresponsive.
D
dlavigne
Guest
Something else is going on. What's the hardware specs? Any issues with SMART tests? Or zpool status?
NASbox
Hardware specs - i7-2600 / 32GB DDR3 RAM - Idle system.
Thanks Dru, I thought I checked, but I only checked zpool status on 11.1-U7. To answer your question specifically, I took a chance and rebooted on 11.2-U7 and repeated the zpool status:
#>zpool status
  pool: BACKUP02
state: UNAVAIL
status: One or more devices could not be opened.  There are insufficient
        replicas for the pool to continue functioning.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-3C
  scan: none requested
        NAME                    STATE     READ WRITE CKSUM
        BACKUP02                UNAVAIL      0     0     0
          12501387109407037534  UNAVAIL      0     0     0  was /dev/gptid/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Turns out that I left a backup drive in that wasn't removed properly. This pool consists of a single disk vdev, and it is only mounted/accessed by scripts from the command line. As soon as I put the disk back in, the messages stopped. I properly remounted and immediately exported BACKUP02, and the messages have stopped and AFAIK the system is now stable/functioning correctly.
I am considering this matter resolved and attributing it to sloppy procedures.
My situation was not the normal use case, but is very similar to what would happen if a single drive pool failed on boot-something that might happen in actual use
@dlavigne for the benefit of the community, I decied to simulate this situation:
  • Using 11.2-U7, connected BACKUP02
  • Powered off the system using the GUI
  • Disconnected the disk (hot swap mount)
  • Powered the system back on
  • Tailed the messages on /var/log/messages
  • Reconnected the disk - The messages stopped (see below)
Dec 11 00:56:30 freenas ZFS: vdev state changed, pool_guid=1487853121776782679 vdev_guid=12501387109407037534
Dec 11 00:56:30 freenas ada3 at ahcich5 bus 0 scbus6 target 0 lun 0
Dec 11 00:56:30 freenas ada3: <WDC WD100EFAX-68LHPN0 83.H0A83> ACS-2 ATA SATA 3.x device
Dec 11 00:56:30 freenas ada3: Serial Number XXXXXXXX
Dec 11 00:56:30 freenas ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Dec 11 00:56:30 freenas ada3: Command Queueing enabled
Dec 11 00:56:30 freenas ada3: 9537536MB (19532873728 512 byte sectors)
Dec 11 00:56:31 freenas ZFS: vdev state changed, pool_guid=1487853121776782679 vdev_guid=12501387109407037534
Dec 11 00:56:32 freenas ZFS: vdev state changed, pool_guid=1487853121776782679 vdev_guid=12501387109407037534
@dlavigne I don't know if you want to refer this to the development team, but I would think that the frequency of this error message (65 messages/second on my system) should be reduced and something done so that this condition doesn't cause the system to become unresponsive (based on log messages I think it took about a half hour for that to happen).
It can't be a problem in FreeNAS since you imported/created/mounted that pool at CLI (not supported). More likely something that might be corrected in FreeBSD or ZFS.
If a pool isn't able to mount at boot, it shouldn't show up in zpool status. Pools managed with the GUI behave like that, so your scenario shouldn't happen during supported use of FreeNAS.
NASbox
I just put it out there incase anyone cares. The pool was created using the GUI, but subsequeintly I took it over using the command line.
If someone has a test system they aren't worried about, it would be a good idea to repeat this test with the gui. Create single disk pool, power off, remove SATA cable and reboot. See if it causes the system to crash. If it is a FreeBSD/ZFS issue, then someone with some cred can file a bug report as appropriate.
