Deleting a Zombie Pool (a pool where you didn't export it first and the disks are now gone)
Can you show the screenshot of your pool list again now and also the output from zpool status
Vincent Jansen
Last login: Mon Jul 17 22:06:51 on pts/5
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS
TrueNAS (c) 2009-2021, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
http://truenas.com
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@Collection14:~ # zpool status
pool: RaidZDisk4
state: ONLINE
NAME STATE READ WRITE CKSUM
RaidZDisk4 ONLINE 0 0 0
/root/sparsefile ONLINE 0 0 0
errors: No known data errors
pool: RaidzDisk1
state: ONLINE
RaidzDisk1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/0ac8646d-1ffe-11ee-9e53-3cecef04411c ONLINE 0 0 0
gptid/0ab99876-1ffe-11ee-9e53-3cecef04411c ONLINE 0 0 0
gptid/0afc9359-1ffe-11ee-9e53-3cecef04411c ONLINE 0 0 0
gptid/0ae92b04-1ffe-11ee-9e53-3cecef04411c ONLINE 0 0 0
gptid/0b165231-1ffe-11ee-9e53-3cecef04411c ONLINE 0 0 0
pool: RaidzDisk2
state: ONLINE
scan: scrub repaired 0B in 11:32:41 with 0 errors on Sun Jun 25 11:32:42 2023
RaidzDisk2 ONLINE 0 0 0
gptid/86a42b95-41b1-11eb-a219-3cecef04411c ONLINE 0 0 0
gptid/87739681-41b1-11eb-a219-3cecef04411c ONLINE 0 0 0
gptid/884ae57c-41b1-11eb-a219-3cecef04411c ONLINE 0 0 0
gptid/892c1253-41b1-11eb-a219-3cecef04411c ONLINE 0 0 0
gptid/8a0a163f-41b1-11eb-a219-3cecef04411c ONLINE 0 0 0
pool: RaidzDisk3
state: ONLINE
scan: scrub repaired 0B in 07:08:26 with 0 errors on Mon Jul 17 20:54:15 2023
RaidzDisk3 ONLINE 0 0 0
gptid/f26c58c3-1cee-11e6-8e16-d050991b63bd ONLINE 0 0 0
gptid/f3390957-1cee-11e6-8e16-d050991b63bd ONLINE 0 0 0
gptid/f40d731d-1cee-11e6-8e16-d050991b63bd ONLINE 0 0 0
gptid/f4e218ac-1cee-11e6-8e16-d050991b63bd ONLINE 0 0 0
gptid/f5b88419-1cee-11e6-8e16-d050991b63bd ONLINE 0 0 0
pool: RaidzDisk4
state: ONLINE
RaidzDisk4 ONLINE 0 0 0
pool: RaidzDisk5
state: ONLINE
scan: scrub repaired 0B in 15:14:06 with 0 errors on Sun Jul 2 15:14:07 2023
RaidzDisk5 ONLINE 0 0 0
gptid/5d5a34e7-25ac-11eb-b303-3cecef04411c ONLINE 0 0 0
gptid/5e2b93fd-25ac-11eb-b303-3cecef04411c ONLINE 0 0 0
gptid/5ee9940b-25ac-11eb-b303-3cecef04411c ONLINE 0 0 0
gptid/5f99c8e2-25ac-11eb-b303-3cecef04411c ONLINE 0 0 0
gptid/60601180-25ac-11eb-b303-3cecef04411c ONLINE 0 0 0
pool: RaidzDisk6
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
RaidzDisk6 ONLINE 0 0 0
gptid/55629af3-2499-11ee-b928-3cecef04411c ONLINE 0 0 0
gptid/5570ca0f-2499-11ee-b928-3cecef04411c ONLINE 22 0 0
gptid/55918c64-2499-11ee-b928-3cecef04411c ONLINE 0 0 0
gptid/5585cb6c-2499-11ee-b928-3cecef04411c ONLINE 0 0 0
gptid/56fc967e-2499-11ee-b928-3cecef04411c ONLINE 0 0 0
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:17 with 0 errors on Sat Jul 15 03:45:17 2023
boot-pool ONLINE 0 0 0
gptid/95dc2146-8eff-11eb-a081-3cecef04411c ONLINE 0 0 0
p.s. The unhealty state is new today. I have to look into that. but thats 6
OK, so you have 2 pools named almost the same, both using the same sparsefile as a disk, only one of those visible in the GUI.
I would start by getting rid of the one we didn't need from the start...
zpool destroy RaidZDisk4
Then try disconnecting from the GUI on the remaining one (RaidzDisk4), which you can see there.
Vincent Jansen
strange. I see it in the list but when I run zpool destroy RaidZDisk4 I get the error:
root@Collection14:~ # zpool destroy RaidZDisk4
cannot open 'RaidZDisk4': no such pool
Vincent Jansen
New development. Raidzdisk6 is a selection of reformated disks that used to be in raidzdisk4. Started getting read error on that pool after a day, so two of those disks are bad for sure. So, with all the disks still in I decided to remove raidzdisk6 after a day. However, when trying to remove that pool, I also get the same error at 20% marker. So cant remove that one either. I think there is more wrong here. Would installing truenas scale resolve this maybe.
Scale may or may not be able to handle the mess differently.
You might want to try destroying both disk4 pools at CLI in either order. Then recreate the right one.
Vincent Jansen
Now I have 2 zombie pools in the GUI. But both are destroyed.
root@Collection14:~ # zpool destroy RaidzDisk4
cannot open 'RaidzDisk4': no such pool
root@Collection14:~ # zpool destroy RaidzDisk6
cannot open 'RaidZDisk6': no such pool
I do think something is broken in the OS since both 4 and 6 gave me the same error when trying to remove in the gui.
I think you got the capital wrong at the CLI for disk6...
Vincent Jansen
no I did it correct before. I just did these command back to back to show all was removed. But it was already removed correctly before.
cannot open 'RaidzDisk6': no such pool
Vincent Jansen
Update. I disconnected one of my mirrored boot disks. I recently changed from bios to uefi boot. Apperently it kept booting from the second disk.
After I made sure only the correct disk was connected and booted The export and disconnect botton was large and red. So I tried it and it worked for raidzdisk4. Pool 6 was already removed. I did have to import my new RaidzDisk1 manually. But now all seems fine.
sretalla thank you for your patients with me. I really appreciate the help.​
