the smartctl for my drives
sudo smartctl -a /dev/ada1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD60EFRX-68MYMN1
Serial Number: WD-WX21DA4D1JHA
LU WWN Device Id: 5 0014ee 20b55c1d2
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5700 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jul 9 16:02:07 2015 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 7784) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 731) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 206 197 021 Pre-fail Always - 8683
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 13
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1554
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 13
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 3
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 39
194 Temperature_Celsius 0x0022 119 105 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 1347 -
# 2 Short offline Completed without error 00% 1285 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[pbearne@bearne-nas ~]$ sudo smartctl -a /dev/ada2
Model Family: Apacer SSD
Device Model: 16GB SATA Flash Drive
Serial Number: B051448130070000027F
Firmware Version: SFDE001A
User Capacity: 16,013,942,784 bytes [16.0 GB]
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jul 9 16:02:10 2015 EDT
was never started.
Self-test execution status: ( 255) Self-test routine in progress...
150% of test remaining.
data collection: ( 32) seconds.
capabilities: (0x1b) SMART execute Offline immediate.
command.
No Selective Self-test supported.
power-saving mode.
No General Purpose Logging support.
SCT capabilities: (0x0039) SCT Status supported.
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1560
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 23
167 SSD_Protect_Mode 0x0022 100 100 000 Old_age Always - 0
168 SATA_PHY_Err_Ct 0x0012 100 100 000 Old_age Always - 0
175 Program_Fail_Count_Chip 0x0013 100 100 010 Pre-fail Always - 0
192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 14
194 Temperature_Celsius 0x0023 100 100 000 Pre-fail Always - 40 (Min/Max 30/60)
163 Max_Erase_Count 0x0000 100 100 001 Old_age Offline - 347
164 Average_Erase_Count 0x0000 100 100 001 Old_age Offline - 299
166 Later_Bad_Block_Count 0x0000 100 100 010 Old_age Offline - 0
241 Total_LBAs_Written 0x0000 100 100 000 Old_age Offline - 3489147394
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
[pbearne@bearne-nas ~]$ sudo smartctl -a /dev/ada3
Serial Number: WD-WX31DA43KK1C
LU WWN Device Id: 5 0014ee 20b5604a6
Local Time is: Thu Jul 9 16:02:18 2015 EDT
was never started.
been run.
data collection: ( 5024) seconds.
command.
power-saving mode.
recommended polling time: ( 703) minutes.
3 Spin_Up_Time 0x0027 209 199 021 Pre-fail Always - 8508
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 41
194 Temperature_Celsius 0x0022 120 105 000 Old_age Always - 32
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
No Errors Logged
# 1 Extended offline Interrupted (host reset) 80% 1334 -
# 2 Short offline Interrupted (host reset) 90% 1309 -
# 3 Short offline Completed without error 00% 1285 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[pbearne@bearne-nas ~]$ sudo smartctl -a /dev/ada4
Serial Number: WD-WX31DC4CKJZS
LU WWN Device Id: 5 0014ee 2b67481db
Local Time is: Thu Jul 9 16:02:22 2015 EDT
was never started.
been run.
data collection: ( 3344) seconds.
command.
power-saving mode.
recommended polling time: ( 687) minutes.
3 Spin_Up_Time 0x0027 202 191 021 Pre-fail Always - 8883
194 Temperature_Celsius 0x0022 118 100 000 Old_age Always - 34
No Errors Logged
# 1 Extended offline Completed without error 00% 1346 -
# 2 Short offline Completed without error 00% 1309 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[pbearne@bearne-nas ~]$ sudo smartctl -a /dev/ada5
/dev/ada5: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
